I am using a vodafone sim card in a 2degree lg phone fully unlocked, when sending messages always returns as failed messages
For sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
SOURCE: cannot send message.always message sending failed.
If you happen to have another sim card with you, can we try to use that sim card and see if the phone will send.
Or your sim card on another phone.
-This is to identify for sure is the issue with the phone or sim..
-If you cant send using another phone then get you sim changed or check with your operator.
-If you are able to send on another phone then you may wanna try resetting your phone by following these steps:
A restore by keying in *#7780# when on standby - This will not delete
any data but will restore all the settings back to default.
If
that does not help then you may wanna try doing a soft reset by keying
in *#7370# when on standby - This will reformat the phone. DO NOT FORGET TO DO A BACK UP AS THIS WILL ERASE YOUR ENTIRE PHONE MEMORY.
The security code by default is 12345
If
this fails as well then you may try doing the Hard reset by performing
the 3 finger reset. You can do this by switching the phone on with the
'3', '*' and green 'call' buttons pressed at the same time.
Thank you for using fixya..
Please rate me on fixya and provide testimonial if ever to continue my further assistance..
Testimonial: "It was a great help! thank you! I never thought that you will send a solution that fast. Thank you so much!"
SOURCE: Can't send or recieve picture messages on Bt50 vodafone.
flash it deffenetily its gonna work
