Not sure why you are connecting it to a computer? You should be connecting a micro sd card with the card reader provided, so you can copy and paste software including the N5 system software to the micro sd card. Then put the micro sd card in the n5 then the n5 in the ds lite. (the card should show up in my computer and you should be able to format it with FAT32 system)
please post further comments if I am not understanding the problem correctly
First make sure you have the correct kernel for the card. Go to the website where you purchased it and download the current firmware. Next copy all of that onto the micro sd card. Build folders in you sd card, very simple right click...new folder... enter... then label them correctly .. Label one movies... music... games.. etc... then put your files into the correct folders.. Another common error is that people use to high of a sd card.... some r4 cards only accept up to a 2gb micro card If you use one that is too big it will stick on the loading screen ... If none of this works reload all the software onto the card and start from scratch... hope this helps
For the N5 you need to fully format the 2gb card, don't be tempted to do a quick format because it won't work.
You are right to use version 1.28 but copy each file across individually in the order they are listed when you have downloaded them. Then you can create your 3 folders assuming you want them
Films
MP3
Games
I have spend a few months on and off arguing with these cards but doing as above should solve your problem.
When you say, "Keeps Loading Up..." what do you mean?
If it boots as if they were no N5 card, then I would suggest the N5 card or Micro SD card isn't seated properly and making contact with all the game slot contacts.
What flash card do you have.You may have to reformat the Micro SD card then put the Firmware for the Flash Card back on.Oh if you can back up any games and saves you have on the Micro Sd first do that.
found solution to R5:
download latest firmware (1.19 at present) and unzip
format MicroSD to Fat or Fat32
Copy firmware onto MSD in this order ONE BY ONE !!!!!!
This step is very important!!!!
1. DS_MENU.DAT
2. _AXMENU.DAT
3. _DS_MSHL.DNS
4. _SYSTEM_ folder
5. moonshl folder
Then load your .nds files into the root.
I've had absolutely no problems with this card so far and if
installed correctly it works brilliantly!!!
