Monitor works when plugged into another computer but as soon as i plug it in to my emachines computer it goes into sleep mode so i think the problem is with the comp. itself . ve had problems like this before on another computer and ended up getting rid of it . please help.
Plug monitor into another known working computer. If it does not work then the monitor has died a noble death. If it works in other unit then the video card of the Dell needs to be replaced.
eMachines flat-screen monitors offer high quality at low
cost.
eMachines flat-screen monitors are compatible with most
brands of PCs.
Issues with eMachines flat-screen monitors can arise from
faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each
possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm
that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the
eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal"
message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video
port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the
monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1
side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the
monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI
port.
Set your monitor to VGA if connected to your computer's VGA
port.
Connect the eMachines monitor to a known working computer
with a known working video cable if the problem persists. Contact Gateway,
eMachines manufacturer, if the monitor issue is not resolved.
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
When the monitor says no signal, it means that it is not detecting a monitor. You need to check the cabling of your monitor and verify that it is properly plugged in. Normally its a blue VGA connection or a white DVI connection that goes to the back of the computer. Also, some monitor requires a seperate power source and you need to check this as well
Try to restart ur PC then it will auto detect ur monitor via DVI input. Actually, no driver needed for monitor in now day, they all come with plug and play.
Need to verify whether its a monitor issue or a computer issue. Get a known working monitor and hook it up to the computer. If you get video then you know for sure the original monitor is bad.
If you still don't get video then you know its going to be either a problem with the video card or the computer.
First make sure the power cord is plugged in both ends (in the wall and in the monitor). When the computer is turned on, it should run a power on-self test and then beep. The monitor light should be green and then the Windows splash screen will display. If your computer starts up but the video fails, then the monitor light will turn yellow. A monitor light that just flickers and goes off is probably an indication that the monitor has failed. I usually try to hook up another monitor (borrow it from a friend) just to be sure that the computer is working.
Sounds like a bad video adapter. I'm assuming your emachines has an integrated video adapter. Put in a video card (with the power plug pulled out! Touch the bare metal frame of the computer with your hand before inserting the video card into the agp or pci slot Don't touch the motherboard). If you get video, you may or may not need to install drivers after that. XP has a lot of video drivers, but lacks quite a few of them, too.
First of all, most monitors now a days are plug and play. Make sure the monitor is secure on both sides. There is also another connecter like the one attached to the CPU on the monitor, so make sure they're both securly attached. Also make sure you have the connector plugged in the correct monitor port. some computers have 2.
