Question about Sony BRAVIA® DAV-HDX576WF Theater System with Wireless Speakers
Volume Problem with my TV and Home Theater system
I just got a Sony Bravia Z-Series KDL-46Z4100/B 46-Inch and DAV-HDX576WFBRAVIA® Theater System from Circuit City.
Here is my problem:
When i use the DVD player/Amp to play DVD, the sound is loud and perfect.
But when i watch TV/playPS3, the volume is low and i have to turn my dvd player/amp's volume to max to listen the same volume as my TV speaker's volume 25.
Here is my set up
DVD player/amp input<----RCA cable---->TV output
DVD player/amp output<----HDMI cable---->TV input
PS3 <---HDMI cable---> TV
My decode setting is Prologic on my DVD player
Seems like if I unplug the HDMI cable for TV<->DVDplayer I won't be able to play sound from home theater system at all too.
Do I have my set up wrong or having the wrong cable?
Please help =(
  • jaideepr Jan 11, 2009
    I had the same problem and I tried it with the TOSLink cable, it improved but not as good, I am wondering what else to do. If I switch to TV sound it is much louder than the sound from the home theater. I have the SONY 46W4100 TV and I thought they will sync well but, doesn't look like,Any suggestions about what else to do?
  • 3 Answers
I had the same problem with mine.The solution I found was to use an optical audio cable rather than the red and white RCA audio jacks. Hope this helped.
Posted on Jan 03, 2009
  • Syed Mahmood Sep 27, 2013
    can you please specify the name and number of the cable
SOURCE:
Horizontal lines flickering at the bottom of screen...... SONYbrvia KDL-32L 5000
Hi Freddy Pagan
I like your Sony TV is defective that it cannot be fix again, better call the Customer Support to replace your Sony TV.
I hope my solution may help you.
Thanks for using Fixya...;-)
May 06, 2014 | Sony Bravia L-series Kdl-32l5000 32-inch...
Hi i have a silly question??? i have a sony bravia kdl-32bx300 television and a sony dav home theatre system so i have connected it and all and it works just fine except .... i would like to know what do i...
If you get your TV programming froma Cabel or Sat Box, run the audio directly from it to the DAV. There is never a compelling reason to pass audio through a TV on its way to audio gear.
Feb 05, 2011 | Audio Players & Recorders
Hi, i have a DAV-DZ330/DZ730 and i cant get sound from the tv/sky. TV is a bravia KDL 40NX503. Its HDMI connected and ive been through the sync process and made sure the hdmi settings are ON on the amp. No...
i had the same problem with my dz330. simply attach you sky box via scart to the back of your sony box and hey presto you should have sound when selecting tv mode from the sony remote
Aug 14, 2010 | Sony DAV-DZ100 System
Have a sony KDL - 46v5100 volume problem
Tap the "Theater" button on the remote. You should see either "Theater Mode: On" or "Theater Mode: Off". If it is off, tap it again to turn it on and wait for it to go away. Now tap again (should say "Theater Mode: On") and then press and hold it for about a second. This should actually turn it off, as opposed to just pretending to. Works on my larger Sony KDL.
Jan 15, 2010 | Sony KDL 46V5100 46 in. LCD HDTV
Turn demo mode off on Sony Bravia home theater
On your remote;
Press the Home button
Scroll left to settings
System settings
Auto-start up - go through setup and select "Home" (not store)
Sorted
Dec 06, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
DAV-DZ260 + KDL-32V4000 - no audio from TV to DAV via HDMI
Check DAV amp menu and select DTS surround or any other digital sound option.
Jun 15, 2009 | Sony Audio Players & Recorders
Sony BRAVIA® DAV-HDX576WF Theater System with Wireless Speakers Logo
721 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
