I just unpacked and set up my new monitor only to find a 1.5 inch wide set of colored lines running the height of the screen right between the middle and right side of the screen.
SOURCE: Monitor displays wide vertical stripes/bands
That is the symptom of failed T-CON board (part of the LCD panel assembly, new panel will be needed), you can try reseating the ribbon connector on the LCD panel first.
This what T-CON board looks like:
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
SOURCE: I have a Planar PT1814NUV monitor that powers up,
This the symptom of failing T-CON board which is part of the LCD panel assembly, the LCD panel will have to be replaced.
It will get worst with more lines/bands.
Testimonial: "Quick responses!"
SOURCE: on Planar PL1700 monitor, screen stays black after power failure
this is a common problem with the capacitor, try opening your monitor and see if there is a capacitor swalow like gonna blow... the capacitor has a form like a AA battery... if changing the capacitor the problem persist maybe is a problem with the board and you need to search if the board have continous power....
