Question about Sanyo Televison & Video
Dp50740 power led goes on and off
I have a Sanyo dp50740 that I bought knowing it didn't power on. Bought a new power supply board for it, and now I get an audible "click" with the power LED coming on for 5 seconds or less, then turning back off. Any ideas on where to go from here? Thanks.
  • Sanyo Master
  • 933 Answers
What you have is most likely a failed main board. These sets are known for this problem. There are several different variations of the main boards. Make sure you order one that matches yours. The main board part # will start with J4@#. The main board part # should be on a sticker either on the main board itself or on the coax input terminal casing. I hope you got the TV for a good price !!!
Posted on Sep 02, 2012
  • 8 more comments
  • Dustin Loomis Sep 04, 2012
    This is my first TV repair, but I come from a strong computer repair background so I think I'll figure it out eventually. Didn't pay much for the tv since he thought it was junk. Will let you know what happens when the main board comes in.
  • Dustin Loomis Sep 08, 2012
    Replaced main board, still not firing. Same thing. Any suggestions?
  • Back2life Electronics Sep 08, 2012
    May I ask where you purchased the main board from? When you plug in the set, does the standby light come on? Did the previous owner mention anything about the set being hit by a surge?
    also, do you have a multimeter handy? We have to start checking voltages.
    I got the board from eBay from a seller called Payless Components. I ordered a power board from them and that worked fine. No mention of a surge, just wouldnt turn on one day. Yes, I have a multimeter. How do I check voltages off the power board if the fail safe is tripping? Standby light does not stay on. Power board clicks on first attempt, with solid power light. Then light flashes and off again. Trying again without unplugging will not produce click.
  • Back2life Electronics Sep 09, 2012
    Plug the set into an outlet, and check the standby 5vdc power supply. There should be a terminal(s) on the power supply that are labeled 5vdc. Also take a peek at the buffer boards, y & z sustain boards for signs of damage.
    I've come across a few Sanyo plasma TV's that would come on, then turn themselves off. In those cases it was the main board.
    A defective main board could cause your problem, as well as a bad power supply, a bad Y sustain, Z sustain or buffers boards
  • Cristina Martinez
    Cristina Martinez Feb 12, 2019
    How didi it go ? Did you fixed it im having the same problem with a tv that i bought a week ago i changed the power supply board and it didnt worked just like yours.
  • Cristina Martinez
dsacco86
  • 1077 Answers
SOURCE: Sharp LC-26D43U Power light flashes and unit won't turn on?
It's a power supply related problem. When it turns itself off, this it called protection mode. The TV automatically turns off to protect other parts form being damaged.
The most common problem is the Power Supply Unit or the Backlight Inverter Board.
You may have to take the TV to a repair shop to find out which one is bad. Paying a repair shop to replace the board for you maybe more than the TV is worth. If you let them diagnose it and you replace the bad circuit board yourself, it would be cheaper.
Here's a place I use to get parts for TVs:
http://www.shopjimmy.com/catalogsearch/result/index/?q=LC-26D43U&p=1
The problem is the repair shop may charge you double or three times of what the part costs at the web site link above. Then, plus labor. I just want to save you money. :)
Posted on Jun 03, 2009
SOURCE: Panasonic TH-50PE700U red light flashing 6 times
Replaced the sc board and tv works fine again.
Posted on Jan 22, 2009
SOURCE: samsung s42sd-yd01 plasma television wont power up
hI MY NAME IS COL, COLINDAWSON@ROCKETMAIL.COM, I have the same TV with the same problem. It has something to do with a 'dew' sensor inside that trips it out when it senses moisture. It seems after a while the sensor gets carried away and cuts the unit out as it is with your TV. We found if you blow a hot hair dryer through the vents at the back for a few minutes, it will eventually come back on. Once the TV is warm the problem stops. I dont know exactly where the sensor is, and if you find out id love to know. Hope this is of some help. Also im trying to find a replacement remote for the same TV as mine is missing.
Posted on Jan 30, 2009
SOURCE: pioneer pdp 502mx goes to standby no picture after power on
Contact Pioneer at 1-800-421-1404 about getting an in-home power supply replacement. This is a known issue with some plasma displays. Some of you would experience a loud pop and then the power supply fails. You get a red light below the ON button, when you press on, the red light will turn green for a second and then back to red. The plasma display will not turn on after the power supply fails. Call Pioneer at 1-800-421-1404.
Brought to you by http://abstravel.com and http://reservaciones.com
Posted on Mar 29, 2009
rommelalilin
  • 2178 Answers
SOURCE: I have a Polaroid 42" TLX-04244B. When turning the
The Inverter is trying to produce the high voltage to light the backlight. It looks like it cannot hold the charge to maintain the high voltage level in order for it to stay on - you get a momentary display at initial power-up thus see the logo. Replace the Inverter board.
Posted on Oct 24, 2010
Sanyo DP42848 screen goes blank after few seconds have replaced main board both converter boards power supply has all voltages screen showes connect all cables or channel up or down when first turn on then...
I had the same thing happen to a DP42848 I'm repairing but I could smell ozone on the left side so I didn't replace anything. I just disassembled the screen and found four flouresent tubes not working! I exchanged them to be sure it was the tubes and it was.New screen is out of the question. I am trying to find a broken used LCD screen somewhere and rob the tubes from it as they just snap in and that might not happen so goodbye tv!
Oct 11, 2011 | Sanyo 42 in. LCD TV
Power light flashing green. No other light or sound. Per directions I found here, I bought a new power supply board. No change at all. Any other ideas?
Ur tv still having the same result a flashing LED power light indication,after u change the tv power supply board.Mean only one thing the main logic Tuner signal board it is also dead too.The Tuner signal board that the board where the tv incomming broadcasting signal wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish main logic Tuner signal board for the replacement.Tries out the old power supply board with the new refurbish main logic Tuner signal board too 50/50 the old power supply could be still functioning.If ur old power supply board still good and functioning,than return ur new bought refurbish power supply to the vendor u bought it from to get some money back.
Sep 14, 2011 | Televison & Video
I bought the tv last week. When I turn the tv on, it takes 5 minutes before the volume goes on. And I hear a little static noise at times. I rebooted by taking the plug out of the back and pushing the...
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
May 27, 2017 | Vizio XVT3D650SV 64.5 in. 3D LED TV
Coloredeagle@hotmail.com I have a sanyo model dp37647, when powered on, the screen flashes and looks like cracks in it, then it goes black.
If I didn't know any better, your description makes it sound like this TV fell over onto it's back.
You will probly have to replace the set, since I would personally recommend a new Power supply board and perhaps, LCD Display.
Both of which would cost close to what you paid for the set to begin with. Buy a nice Vizio! :)
Aug 23, 2011 | Sanyo DP37647 37 in. LCD TV
Hi, I bought a Vizio L32 HDTV10A that didn't power-up. There were charred components on the power board (an 8-pin IC with heatsink and 2 resistors). I replaced the power board, and the power LED then...
change the mother board. the ic took a hit after the power board went off. it will test good without stress, but under power stress it break down. measure the output with osciloscope to check the waves you should get a saw tooth wave if the the ic is good under stress.
Mar 07, 2017 | Televison & Video
Turned my sanyo dp42410 off last nignt and now it wont turn on no led light on he front nothing
Good day!
The problem of your TV is on the power supply.
Please follow this procedure for D.I.Y troubleshooting.
  1. Remove all screws at the back.Open the cover.
  2. Power ON the TV.Check the input voltage of power supply from the cord.If supply form the power cord replace it.
  3. If you have voltage supply from the cord.Check output voltage form the power supply board and for sure you have no supply on it because the indicator didn't lights up.
  4. Check your power supply board such as fuse if busted,power transistor and diodes if shorted,open/change value resistor and leak/bulge on top capacitor.
  5. If you found that replace it and try to power it on again.Then check the output voltage such as 5vdc for the system board,12vdc for the sounds and 24vdc for the inverter.
  6. If you got that 3 supplies your TV is OK.
Note:If this procedure is not fix your problem it means the power supply got a major trouble and not for D.I.Y..I suggest to you as a technician to buy a new power supply board or give to the qualified technician.
I hope this solution will be helpful.Thank you very much and good luck.
Apr 20, 2011 | Sanyo 42 in. LCD TV
We were just watching tv and it just shut off. Now it won't turn back on. I already unplugged it and still nothing except for the green light will come on for a second then turn right back off. You can...
Now tv on,power LED light indication flashes?Yes.The power supply board is the problems and the causes.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Mar 24, 2011 | Televison & Video
TH-15A won't make sound. Comes on, then flashing front light
This probably means there is a failure and the internal protection circuits have activated. It will probably have to go to a shop for repair.
Jan 03, 2011 | Mackie ProFX8 / TH-15A PA Package
Sanyo Vison model CLT2054 - three years old. Screen goes black shortly after turning it on. Is this a common problem? Is there an inexpensive fix?
clt2054 Sanyo vizon 20" TV
At power on my screen blinked on for a second, then went black for a minute or so, then blinked back on, this repeated. I noticed the external 12 volt dc 5 amp power supplys green light blinked on & off with the TV but it blinked off just before the TV did, indicateing that the problem was a power supply problem. Then I put the PS transformer up to my ear and could hear it buzz as it powered on each time. The buzz increased in frequency rapidly then stopped as the internal heat fuze/thermister er something, shut it off for a minute untill it reset. A person could buy a new Power Supply transformer for $14 to $40, or could try to fix their PS. But I simply hooked it up to a 12v car battery & the TV worked. On the back of the transformer is the pinout for the 12v 4 prong plug that goes into the TV. On the TV the bottom 2 pins a 12v+ & the top 2 pins are 12v negitive. Nails with the burrs filed off fit into the sockets, a strip of thin card board between the pos & neg nails for an insulator, & aligator clip jumpers on them to the battery got me a working TV. So I now know it was a power supply problem. I could follow the advice of others on this great FixYa site & try to fix my PS capacitor problem ? Or buy a new PS, or just put the TV in my 12v veggie oil diesel magic buss, er camper thingie. AND please don't send anyone $19.99 for free advice.
I hope this helps someone in somehow.
bitdog
Dec 21, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Televison & Video Logo
768 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
