I have a 4+ year old propane fireplace and today when I was checking the propane tanks level I noticed that the fireplace vent has a black soot above it. What could be causing this?
Professional was out and It was propane settlement from the propane tank. Flames were buring normal. No biggie just don't let propane level get that low again. Professional was out and It was propane settlement from the propane tank. Flames were buring normal. No biggie just don't let propane level get that low again.
AnonymousJan 20, 2009
I have a new ventless propane heating unit and have black soot covering the inside brick wall, filling our ac vents, air purifier, on our curtians and even a black soot film covering products in our cabinets. The dealer replaced the unit, but I have felt ill for a month. Are there any medical symtoms that can be a direct result of breathing htis propane soot for a month?I have a new ventless propane heating unit and have black soot covering the inside brick wall, filling our ac vents, air purifier, on our curtians and even a black soot film covering products in our cabinets. The dealer replaced the unit, but I have felt ill for a month. Are there any medical symtoms that can be a direct result of breathing htis propane soot for a month?
i have the same problem. i have a 'gas brick' heater (in wall unit) and began noticing soot. so the problem is my husband waited too long to order more gas? just want to know for sure so i can inform him. if we go ahead and fill up now will the problem resolve itself? i believe the tank is low now. or since spring has kicked in , should i try to burn up that 25%of the gas tank by using the gas in my gas stove cooking?
AnonymousMar 13, 2014
black smoke stains on vinyl siding beside propane fireplace ventblack smoke stains on vinyl siding beside propane fireplace vent
You can't post conmments that contain an email address.
Hi, propane heaters are very well known for Sooting up. If the gas pressure is not correct on the MGV, this will cause the heater to soot up fast. You will need to have the inlet and manifold gas pressure checked at the tank and heater. This furnace has to be cleaned up!! You will need to call out a tech to check the inches of water column. Shastalaker7 A/C & Heating Contractor
Is a Vented or Vent-free gas fireplace? I really suspect it's Vent-free (ventless) as a vented unit, unless the direct vent is clogged exhaust everything, including 85% of the heat out side.
Here are the things that will cause a Vent-free Gas Fireplace to soot.
Not having the fireplace cleaned and serviced, at least annually by a qualified technician.
Misplaced logs that impinge the main burner flames.
Running a ceiling fan at the wrong speed and in the wrong direction while fireplace is burning.
Burning scented candles while burning the fireplace.
Low Gas Pressure to the burner.
Here are the solutions to the above listed causes:
Have the fireplace cleaned and serviced.
Check your Owners Manual concerning the proper placement of each log,
Run the ceiling fan Counter Clockwise and at the slowest speed. The fan on the side of the switch should be in the UP position for Winter and Down for Summer.
Scented candles soot any way. Add the warm moist heat of the Gas Fireplace and they'll soot 50 times worse. The scent is not natural, it has an alcohol base like after shave & cologne. Stop burning scented candles. It has been proven that they greatly contribute to indoor air pollution.
Low gas pressure causes incomplete combustion, which causes the burner to soot. Have it checked by your propane provider.
Based on my 15 years in the hearth and home business and having sold and installed hundreds of these appliances, I am will to bet, it's a cleaning and servicing issue or misplaced logs.
Hope this helps you solve your sooting problem. I woud really like to know how it works out for you. Please let me know at [email protected]
Hi, sounds like you could have an obstruction. Check the entire stack for bird nesting materials or debris. The propane, when it burns, should not produce any soot. My guess is that something else is burning in your chimney stack and if it is blocked, it will come into you room. Once you remove the debris, you should attach some wire mesh around the exit to avoid any heat seeking animals from nesting again.
Hope this helps.
Remove the burner and clean all holes ,typically at the end of the burner is a cheep sheet metal valve.This valve adjusts the air to gas mixture by rotating it to increase or decrease the combustible air intake.Air must be sucked into the burner as natural gas is injected into it, this makes for a clean flame,The flame should be blue with small yellow tips.If the flame is long and yellow and sooty increase the air intake on the burner valve.
Thanks for your question, your problem is either impingement on your log set, or a product of incomplete combustion, if you notice soot on your logs, then you will need to take them out, clean them, and reinstall them as to not have the flame touching them, you will need to clean the burners as well, make sure nothing is laying across the burners, as this too will cause sooting, as far as incomplete combustion, was this model a natural gas converted to propane or the other way around ? if so who ever converted it, did they adjust the gas valve according to specs? improper adjustment will cause sooting or hooking up a natural gas unit to propane will do this too, I will recommend using (Rutland White Off) to remove any soot from your glass, it works fantastic for this ! any ace hardware will carry it, please do not use windex or any other cleaner on the glass as it will more than likely leave a rainbow affect on your glass once the glass heats up, hope this was helpful to ya, please rate this solution, thanks agai mr.grzz
A clue to what could be wrong is that you mentioned it took 10 minutes for the pilot to go out. It could be your gas valve. Get a technician in to check your gas pressure both before the gas valve and after. Have them check it as the water heater is running.
