There is a rattling noise in the front passenger side under the hood. I could not find anything loose. Any ideas? It rattles while driving and while idling
SOURCE: Rattle/Vibration from front of vehicle when idling at stop
Hi and welcome to FixYa. Please try this:
GO out to the car, and lift up on the hood. Does it raise a bit and rattle? If so;
Open the hood, and look at the perimeter of the front radiator support. You will see 2 small rubber thingys, that look like that they are screwed onto the metal that is holding the radiator. Unscrew them a little, and close the hood. Pull up on the hood and see if the rattle goes away. If not, repeat unscrewing the rubber things until the lift disappears.
A FixYa rating (4 blue diamonds) would be greatly appreciated for my assistance.
SOURCE: 2003 nissan sentra scraping/rattling noise
Maybe its your engine mount that is loose. Try that and let me know if its that.
SOURCE: 2000 Lexus ES300 - 45K
Are you sure this is a rattle or is it more of a creaking noise? I have a 2000 ES300 and had an issue when I would go over speed bumps and the noise would drive me nuts! However replacing the bushing in the top of the strut mount is expensive due to the labor involved.. Replacement of the strut or the bushing isn't necessary. Just open the hood, locate the strut housing and you ll be able to see the black rubber bushing in the middle. Obtain a can of Heavy Duty silicone aerosol spray and attach a straw to the spray tip. Using a flathead screwdriver wedge the screwdriver between the top of the bushing and the metal pushing the screwdriver all the way to the edge of the metal underneath the roof of the metal housing. Then pry the edge of the bushing away from the metal housing so that the top of the edge of the bushing exposed and stick the straw end of the silicone into the spot and spray generously. Only slight bushing movement will be obtained as the bushing is pretty stiff but it will be enough. Work your way around using this technique until you get the spray fully around the bushing 360 degrees getting it into the area between the edge of the bushing and the metal. Then spray the silicone onto the top of the bushing filling it all the way up until it spills over the metal. After it drains down, repeat again making sure you fill it above the rim of the bushing so it seeps into the area between the bushing and he metal housing (or frame) because this is where the rubbing is taking place that is creating that awful noise. Repeat on the other side and your done. The main goal is to get the silicone into the area between the metal and the bushing along the edge. This happens to be the way I was able to do it. This totally solved my problem and now the car is so quiet there aren't any knocking, creaking or rattling noises. This was a hard solution to explain without visuals, hope you can follow. This will work for sure. The Heavy Duty Silicone spray I used was manufactured by CRC and I bought it from Walmart.
SOURCE: 2006 Town & Country Engine Noise/Rattle
If the check engine light is on, take the vehicle to an autoparts store and have them use a scan tool to retrieve any fault code(s) stored in the computer. Most parts stores offer this service at no charge. The fault code(s) will help narrow down the problem/potential problem. Sure hope this helps and best wishes.
