TV turned off on its own. Will not come back on. Standby light in lower right corner is solid red (standby). When I push the power on button, the red standby light cycles as usual and then has a very brief blue (it illuminates solid blue when TV works correctly) and then back to solid red (standby indicator). TV remains off during this cycle and will not come on. I have taken the back off of the TV and none of the PC boards show any visible sign of damage. No bulging caps or cracked circuits that I can see on any board. Can this be a faulty power supply board or main board?
SOURCE: Power Problem with Zenith Z50PX2D
I had the same problem with same model TV a year back, they replaced some board (I was not there at home) as I had warranty and after a year same issue popped up again.. Can you please tell me what board replacement worked for you. I don't have warranty anymore.
SOURCE: HARWA LC37W18S LCD TV using KAS200-5S241812XLS
Check all the caps on PSB. if any look puffed , replace them. If you are getting 14volts to the ivnerter board PS is good and the inverter is bad.. good luck
SOURCE: WONT TURN ON
Most likely, the problem is a defective Main Processor Board. This is the board with the antenna, RCA and HDMI plugs. You cant repair or replace component parts on this board, so dont even try. You must replace the complete board. The TV says Sylvania, but it is a bloody Funia TV. Several years ago this foreign company bought out broke-azzz Sylvania . They are still carrying the Sylvania name since Sylvania was a popular TV name in the 70s. Every electronic company in the USA is now owned by the Chinese, so call Funai and order the part from them. Dont be surprise if they dont have a clue what the heck you asking for. America and all electronics have gone to the puddles. Do you know why? GREED.
SOURCE: tv turns off will turn on then off right away
the internal overload sensor is engaging to protect the system. The parts cost to replace the faulty board is about $70 But you need the skills to open the tv and change it I recommend you get a professional to do it More expensive of course but a lot safer.
Testimonial: "very good im gonna jump right on that thank you "
SOURCE: My Sceptre LCD TV Power turns on briefly (blue
Power supply is the place to look, look for bulging on top of the capacitors in the secondary side of the main power supply.
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
