Unfortunately, you can't use a microSDHC card in the TH1101. The TH1101 was designed to work with microSD cards. The microSDHC is a newer standard; while those cards will fit into the slot, they will not function properly in microSD devices. You'll have to limit yourself to microSD cards 2GB and smaller.
The SDA announced the microSD format at CTIA Wireless 2005 on March 14, 2005, and approval of the final microSD specification was announced on July 13, 2005. At launch, the microSD format was available in capacities of 32, 64, and 128 MB. SanDisk introduced a 2 GB microSD card in July of 2006, initially priced at 99 USD. Since then, prices for flash memory devices have fallen dramatically. The same 2 GB card as of April 2009 can be found for as little as 12 USD at department stores, and as of May 2009 for as little as 6 USD at online electronics stores. At present date Jan 2010 a 16 GB micro SD card class 2 comes for about $40 and a 4 GB class 2 micro SD card comes for about $8. please rate my answer as helpful. thanks. Joe
[Extra Hardwares Needed]
1. MicroSD card
2. "Micro-B" USB data cable
[Procedure - either PC or Mac]
1. Disconnect USB cable (if you connected already)
2. In Xenon phone
Settings -> More -> Connection -> USB Connection
-> (select) Mass Storage
Note: If you don't do this, you will get an error message
"Unable to use liscense. TRy again after formatting memory card."
3. Insert MicroSD card into Xenon phone slot
4. Connect Xenon phone to PC (or Mac) using USB cable
5. If MicroSD is not accessible as a disk drive, then
(1) remove the MicroSD from Xenon
(2) format the MicroSD from PC
(3) retry step# 3 & 4
6. You can drag & drop your folders and/or files (.mp3 or .m4a only)
into the MicroSD card
7. Disconnect Xenon phone from PC then go to "AT&T Music" -> "Music Player"
Note: All features work except for "Playlists"
8. If you want "Playlists", you need to use Windows Media Player and sync.
iTunes doesn't work since it doesn't allow other devices than iPod.
This means that you cannot use Mac to create/sync the playlist.
.to do so plug it and open my computer.(sd card in mp3 player)there should be a mp3 plaer drive and a second one.right click on it and in the sub menu click format
The music might not be in the correct format. Does your phone play MP3s? Another thing might be the DRM problem with the MP3s. I had this problem once and had to strip the DRM stuff out of the MP3 before my phone would recognize it.
You cannot just move WMA songs onto the card and play in the MP3 player. MP3 format may work this way, but for sure the player only seems to be able to recongize WMA files when syncd through Windows Media with the USB cord attached. Be sure the DESELECT 'copy folder hierecy' under the sync options/properties of the MP3 player drive or SD card drive.
When using XP Pro and Windows Media Player you can transfer WMA but you have to go into the PROPERTIES of the drive (mine was mp-556/G: drive) and DESELECT the option to transfer folder hierecy. The MP3 player is not able to reconginize the folder structure it usually creates.
This player only seems to be able to transfer MP3 format with Vista, using windows media player sync. I can syne MP3s formats, but not WMAs at all. Unless someone found otherwise
