Entering Code instructions 1. Take out the SIM card from the phone and switch the phone on. 2. Enter the unlock code into your handset. 3. Now replace your SIM card and turn the phone on. 4. Your handset should now be unlocked.
Entering Code instructions 1. Remove SIM Card from handset 2. Enter Code 1 into the handset (Your handset will display "auto subset lock activated") 3. Enter Code 2 into the handset 4. Your handset should now be unlocked.
a) Enter an alternative network SIM card into your Samsung and reboot. The new network should be displayed in handset window. c) If the process is repeated with yet another alternative network SIM card, you may be requested to input a security or pin code to enable the use of the new SIM card. d) Enter 00000000 (8 zeros) which should enable the SIM to be accepted. e) Finally once again enter 00000000 (8 zeros) and this should permanently unlock the Samsung.
Final alternative Solution if the above fails
Unlock Code #7465625*638*7337#
Your IMEI Number is Invalid,so please Provide the correct IMEI Number,To know the IMEI Number type *#06# then it shows the IMEI number remove the special character and dashes and that is IMEI number,Then it asks for Network Unlock code means it may come 15 or 13,16 digit,Master reset code differ,Network Unlock code to unlock from Network lock,to use other GSM Network Sim card,master reset code to reset from security lock,Get the Network Unlock code from here Unlocking4free.com ALSO get the master reset code there.
since you master reset the phone it may erase everything on the phone even the settings installed, you have to consult your service provider to re configure your network settings.
