I was about to transfer my files to PC, but as I recorded one last scene, I got an error message about the movie function being disabled. I am now unable to read my recording on that one DVD-RW, neither on the handycam, nor on the PC. I tried to convert the 500MB VRO file with two different file conversion programs, but to no avail. Have I lost everything on this CD or is there a solution to this problem?
Any help would be greatly appreciated.
SOURCE: Movie Recording Disabled
guys hope you all found the solution like me who had same issue. if you
noticed, it says about the aspect ratio and that means the formated
disc aspect ratio is not compatible with the aspect ratio your camera
need. so re-formating the dvd with right aspect ratio solved the
problem quickly and we have peace.
bayaraa
SOURCE: recording disabled
bayaraa
SOURCE: movie recording disabled
Just delete unuseful data from drive or connect the camrea to your pc cut the required movie and paste it on your pc drive then it will work.
Thanks for using fixya.
SOURCE: I get a message on the screen that says,
This message appears when mini dvd disc got some error in recording tracks, if its rewritable mini disc then format it as option is available in camera settings menu and if disc is once writable then use another disc as it can not be formatted.
Caution: Format will erase/ delete all files on dvd disc and refresh the dvd disc.
SOURCE: In turning on my handycam,
It seems problem with hard disk that need to be formatted, please make sure you have copied/ transferred recorded files in computer or format HD will delete every thing on HD.
Press Menu button on lcd screen and select settings then select HD and select Format, it will take little time to format hard disk.
Now you can record in camcorder.
Thanks.
