Question about LG 50PB4D 50 in. Plasma HDTV
Remote Controller Codes
The VCR and DVD button on the TV Remote can be programmed for other units. I have a Panasonic SA-PT850W Home Theatre system and the codes in the TV user manual will not function this unit. Does anyone know the code for the Panasonic unit on the LG remote. (LG uses a 3 digit code) The manual suggests 003 or 006 both have failed. thanks, Doug.
5 Suggested Answers
SOURCE:
  • 60 Answers
SOURCE: LG LCD and LG DVD remote codes
If both units are LG you don't have to program anything. Below the power button are 6 buttons labeled TV, DVD, etc. As soon as you push the DVD button the remote should work it. Remember to push the TV button again to make it work the TV.
Posted on Apr 21, 2008
  • 110 Answers
SOURCE: LG Remote problems
Try here:
http://us.lgservice.com/index_b2c.jsp
Posted on May 25, 2009
SOURCE: i have an LG 42lg30 and the user manual does not
Having just bought an LG 42 " tv we found ourselves with the same problem on your sky remote press tv red light flashes once press and hold the select and red key the light flashes twice press tv key again the light flashes once keep on pressing power to turn off tv if that does'nt work press tv and off button repeatedly until eventually the tv switches off and the light flashes twice then press select and there you have it, you can now use your sky control to activate your lg tv
vonnie
Posted on Jul 27, 2009
  • 109 Answers
SOURCE: i am trying to program my samsung tv remote to
http://www.remote-codes.com/
try here
Posted on Nov 09, 2009
Big Button Remote Control
This is because you did not use the right remote code. Try trying different codes and test different functions with your recorder. Try searching on the Pioneer wesbite for remote codes. I would get the codes for you, but I don't have your model number so I can't. You can search for them yourself or comment back informing me of the model.
Hope this helps :)
Jan 25, 2008 | Televison & Video
I need code(s) for my DVD Video, Model #: NB093 remote control to program my Philips DVD Player/VCR, Model #: DVP3345V/17. Can you please help me? I would greatly appreciate it. Here is a picture of it.
http://remotecodelist.com/remotes/magnavox/magnavox.htm lists the code for your device as possibly being 1000, 1001, 1002, 1003, 1004, or 1005. Of course, you also have the option of using the remote controller's "Code Search" button. 25300580-iv4burzhkawezvl2jbah1xae-2-0.jpg With Codes:
Turn on the DVD/VCR unit directly. Continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Enter the four-digit code (1000, 1001, 1002, 1003, 1004, or 1005) for the DVD/VCR unit. The remote controller's light should go off. Press the remote controller's power button, & when the DVD/VCR unit turns off, then you will know that the remote controller has been correctly programmed.
Without Codes:
With the DVD/VCR unit on, continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Continue to tap the remote controller's UP or DOWN channel button ONLY UNTIL the DVD/VCR unit responds. Then, press the power button on the remote controller once the channel has changed. If the DVD/VCR unit shuts off, then press the power button again to turn it back on. If the DVD/VCR unit turns on, then the remote controller has been correctly programmed. Otherwise, repeat this whole process until the remote controller is correctly programmed.
Nov 29, 2014 | Televison & Video
How do i upgrade the sa-pt850 to record tv programs
Find best value and selection for your Panasonic-SA-PT850-dvd-home-theater-system- search on eBay. World's leading marketplace.
Jul 27, 2012 | Panasonic SA-HE70K
How do i program my comcast remote to my panasonic home theater system? SA-HT740 series
I have the solution! Get comcast to give you the remote with the GREY Ok/Select button. There are codes for this remote that support the Panasonic home theatre in a box. You can go to comcast.com and find the remote manual for this to see it for yourself. I have 3 boxes and just got a new one and was trying to do the same as you. I found the old remote for one of my older cable boxes and switched it out, programmed for the Panasonic and it all works quite well!
Nov 15, 2010 | Panasonic Home Theater System System
Panasonic SC-PT850w sound cuts out
Are you watching 10HD off the air from an antenna? You are losing video and audio intermittently, which may just be indicative of a weak signal. Does your TV have a signal meter?
Apr 27, 2008 | Panasonic Home Theater System System
CONNNECTING THE DMR-EZ475V TO A TV, THEATRE SYSTEM AND CABLE BOX
noavatar_s.png jdrrwoods
Rank:wizard_s.gif Wiz
Rating: 84%, 12 votes
http://www.altex.com/product_info.php?products_id=9207 here is a link to a audio / video switch box you need one of these make sure it has several audio video in and at least one audio/video out
hook all you rca1.gif cables up to the audio/video in from the cable box, tv, and dvd/vcr combo then out to the surround sound youll also need to get some rca cable splitters for the out so you can run it back to the audio/video in to the tv as well as the surround sound here is alink to what they look like
http://www.altex.com/product_info.php?cPath=344&products_id=6201
youll need thre of these of course when hooking it up dont pay attention to the color on these just the ones from the tv and surround sound and thats it your done it will all work if you want it to were you dont have to get up and push a button everytime most of them if you push all the buttons in at one time theyll stay like that
Feb 08, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Codes to program Innovage Products Jumbo Universtal Remote
I need the code for my rca tv so I can program the inovage jumbo universal remote Pleaseeeeeeeeeeeeeeee
Dec 31, 2007 | Televison & Video
LG 50PB4D 50 in. Plasma HDTV Logo
27 people viewed this question
Ekse
