Mine wouldn't turn on either....what they do not tell you is that inside, (take out for four screws and open the meter), is another battery under a silver round clip. Take that bettery out and replace it....works like a champ now!.
To reset the tablet, you're going to have to do what's called a factory reset. To do this go into the settings, and look for tablet information. Under that it should contain a factory reset button.
cant log on huh? ok dont panic...i have a few things that u could try or that happened... #1/someone might have hacked into your account somehow...they did that to me too./so,you could either make a new account,or click the button under where u type your e-mail in. it should say :"forgot your password? click that or click the button that says forgot your e-mail. thats all i got... let me know if u need any thing else...
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
hard rest factory default settings = when ur set is switched off press
both buttons call and end key and then press power button on upside of
pda for like 5 sec screen will appear asking to format all data take
out ur card if u dont want to format that now confirm by pressing the
centre action button in 4 side joystick and go
if ur pda boot normally after reset procedure it will take some time to boot dont panic if it is ok then good luck
if it doesnt help then then go to www.htc.com and upgrade ur ROM
Either an interior light or head lights were left on all night, or there's a dead short in the electrical system, or... the battery completely failed internally such as a weak spot or defect in the plates. At any rate, it all obviously points to the battery. Replace the battery.
