Dryer heats and runs through cycle but red moisture light always reads "less". Cycle runs through so fast that clothes do not dry fully. I have to restart dryer two or three times to fully dry a load. Is there a way to test the moisture sensor? If I need to replace a part is it just the sensor or are there other parts associated to moisture readings? Thanks for the help.
SOURCE: not heating properly, many cycles to dry loads
Check the following to address this issue--
Note: Normal drying time for a dryer
is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct,
is not clogged.
Unless regular maintenance is performed, chances are there is a lot
of lint accumulated inside the dryer. This might affect the drying
time and could be a fire hazard. Make sure to have your dryer
cleaned regularly. Because this might involve taking most of the
dryer apart, it is recommended to have a qualified appliance
repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one
of them breaks down, it might affect the dryer's performance.
Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case
it would still work but will take longer time to dry the clothes.
Replace the element if found defective.
SOURCE: The dryer stops heating before the clothes are dry.
Maytag gas dryer MDG7600aww, (Model number corrected). Below is a link, courtesy of www.repairclinic.com showing the parts breakdown and disassembly procedures.
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
This link shows the most likely cause of your issue.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg7600aww-%3d%3di3479&PartID=3479
This link shows the next likely cause of your issue. Remove the front panel and inspect the sensor bar which is located at the 4 o'clock level on the drum bulkhead, ( see the first link for location). Ascertain that 2 wires are connected to it and that black sensor bar is not cracked or broken.
This link will offer more assistance if the above 2 items check good.
http://www.repairclinic.com/0088_8_1.asp#Subtitle_2
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg7500aww-%3d%3di516693&PartID=516693
