A close friends son owns this computer and had to do a Hard boot because the laptop froze. when the laptop restarted it came right up to Operating system not found.
now when i go into the bios it doesnt see the Hard drive at all. i have attempted to run a repair with vista cd but with out is seeing the HD i am unable to repair. i really do not want to open this laptop up and remove hd to extract the data if i can help it.
Thanks for your time
Sounds as if the HDD crashed. No fix but to replace HDD. Sometimes putting it in the freezer 2 hours and then letting it thaw works, but after multiple attempts and the same failure, you will need a new HDD.
Thanks for using FixYa. Your Rating of my solution to your problem was THANKS FOR TRYING. I would appreciate a re-evaluation of your rating - as the answer I gave was correct. There are not many experts that provide answers to FREE questions beacuse anything under HELPFUL reduces their overall rating percentage.
The description FixYa uses for the rating system is misleading - a THANKS FOR TRYING means the answer was not helpful in solving your problem.
We are working toward a better rating description to help alleviate the bad ratings.
I took the time and answered your question to the best of my ability and request a change to at least HELPFUL.
Thank you.
You have no choice but to open it up, this is to check that the hard drive works or has disslodged, pull the hard drive out and then reseat it again, reboot the laptop and see if the bios has found the hard drive, if it does try to boot into it
kind regards
Select models have the ability to have the operating system reinstalled from a hidden drive built into the computer.This will RESET the computer to its Factory Settings( DATA LOSS )
To start the system recovery:
leecom72
I attempted a reseat and this didnt work either. i removed drive and connected it up to another pc as a slave to remove the data so the drive is working in that sense. for what ever reason the bios is acting dumb or the MBR is gone. the vista disk is not seeing the drive either so unable to run a repair. people shouldnt buy Acer lol
acer asire 6920 very slow
Same thing for me. Fantastic
