My macbook has a grey screen look like when tv screen start like black and white? The grey screen is few inches. Sometimes the grey disappears when I move the screen a lot to adjust to normal. It'
if i tilt the screen upwards or backwards and hold my thumb on the screen , the grey lines disappear but reappears immediate if i slightly move my laptop.if i tilt the screen upwards or backwards and hold my thumb on the screen , the grey lines disappear but reappears immediate if i slightly move my laptop.
You can't post conmments that contain an email address.
Leave the Macbook air turned on until the battery goes dead. Then Connect to power and start it up. That should solve the problem. You problem was caused by not letting an update install in full.
Hard drive is dead or the signal from the hard drive is not being read by the ide controller. I'm working on a MacBook 13 inch right now with the same issue. I had a spare hard drive and a windows Vista disc, so I installed the hard drive and inserted the vista install disc and the laptop loaded and installed Vista on the Mac with no issues. I took the hard drive from the Mac and attached an adapter to it and ran it through a usb on another laptop and the laptop could not read the files on the drive....so, the drive was bad.
After doing some research I found out the the closed captioning or text box was accidentally turned on. You can try to turn off closed captioning and that might work, fortunately it worked for me!
this is new hardware. used for like a month
