HI SIR ,I VE T MOBIL PRISM
TOOMANY PATTEREN ATTEMPTS ' SO I WANT TO UNLOCK WITH OUT ERASING DATA CAN U HELP ME PLZ
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
SOURCE: my sony ericsson xperia x10i
patern is locked and i must open with google account but phone dont accept tha email and pasw what can i do ?
SOURCE: Hi, I need help, I have SAMSUNG Galuxy S (I9000),
Do this but make sure you may wan't to lose files:
1. Turn off the i9000 phone or take out the battery and reinsert it.
2. Hold the Volume Down button
3. Press and release the Power button
4. Select Clear Storage by pressing the Volume Down button
5. Press and release the Power button
6. Press Volume Up to confirm i9000 MATER RESET
Done!
SOURCE: locked out by too many
1. On the computer: Start PC Companion™.
2. On thecomputer: In the Support Zone™ descriptor, in the Software Updatesection click Start > (Repair) and follow the instructions on the PCmonitor screen.
3. Turn off the phone.
4. Connect the USB cable to your computer.
5. On the phone: Press and hold down Back key and connect the USB cable to the phone.
6. Follow the instructions on the screen.
Note : The software in your phone will be replaced. All personal data stored in your phone will be lost.
There is also a way to unlock the pattern screen lock by signing in with your Google account.
1. After 30 seconds, tap Forgot pattern?
2. You need to log in with the primary gmail.com e-mail address and not the alternative email address connected to the Google account.
3. Tap the username field and enter the primary Google account user name.
4. Tap the password field and enter the primary Google account password.
5. Draw a new unlock pattern and tap Continue .
6. Draw the new unlock pattern again and tap Continue .
If these options are not available to you, please describe preciselywhat you see when attempting to connect to your PC and use PCCompanion.
SOURCE: I have locked my x10i
i bought a sony ericsson xpera x10i from a guy and i never knew the charging port was bad,now its asking for gmail ID and password,is their any manual code to unlock it ?
SOURCE: my phone is locked, saying
If you forgot your password pattern, that google account should be unlock samsung galaxy S password but if didn't you can reset your phone first then put your google account again. But if still not working i suggest you to bring your phone to samsung service center and asking them to hard reset your phone it will unlock samsung phone to default factory setting. Don't doing hard reset at non authority samsung distributor, it can rush your warranty. I hope my solution can help you, good luck.
