Probably a blown fuse, onthe power supply board, or the entire power supply board is "fried". f you want to investigate anew power supply: http://www.compassmicro.com/parts.cfm
If the rebooting does not do the trick, then the rep is right in telling you that unit is in need of repair. But at what price. Better check that out first since it might be cheaper to replace than repair.
It's more than likely that your internal power supply has failed, you would be wise to take it to a service center if it;s a high value printer, if it's not then buy a new printer.
hi friend,
Run the Head Cleaning utility to clear any clogged ink nozzles. To run the Head Cleaning Utility, follow the instructions below.
For Windows users:
1) Make sure that your printer is ON and the error light is off.
2) Access the printer software.
3) Click the Utility tab, then click the Head Cleaning button.
4) Follow the on-screen instructions
5) When the power light stops flashing, click Print nozzle check pattern in the Head Cleaning dialog box to confirm that the head is clean and to reset the cleaning cycle
If you find that any segments are missing from the nozzle check pattern, you may need to repeat the head cleaning and print the pattern again.
Or u could consult the user manual
u should let the ink settle for 12-24 hrs??? hope this helps u
please rate me..........................
thank u for using fixya
regards sivaranjini
Here is how to set it:
Open the properties page for the RX680 and on the "Main" tab, click on [Advanced]. A Note may appear egarding incorrect settings. Click [Continue]. Find the [ ] Grayscale box and check it, the [OK] [OK], etc.
The Specialty Print service on the Epson RX680 allows you to restore colors in faded photos, correct poorly exposed photos, reduce redeye, and even crop while you copy photos.
Yes you're right. Use SSC service utility or RX680 Adjsument program. Find at indoreset.blogspot.com. Don't forget to replace waste ink pad, or just extend outlet pipe of head cleaning mech to outside.
First question: have you the skills to open the printer? Second: it is affecting the funcionality? If both answers are not, then keep working. If you want to open the printer, find and download the service manual, fin it in google, some places give it free, other ask for a donation and anothers sell all via paypal.Good luck
I had the same issue when the printer arrived. I powered the unit off, moves the ink cradle to the left about 1/2 " then powered it on. Then it worked from there.
