Konica minolta dimage z5 5mp. my camera is working well with a adaptor 6volts. I can only use the adptor. when i take the adptor out, and insert my batteries nothing works (ny batteries i have two sets). the problem started suddenly. I hope you have some solution.??? H. dsouza.
In order to narrow down the issue, I suggest you the following steps. 1) First of all we have to power drain the Camera. Take out the battries and unplug adaptor, now hold the power on putton ( Click Button) for a minute this will clear the static power on Camera. If this doesn't fix the issue, Than.... 2) As cam is working fine with Ac adaport and batterys are not working you have to check the cam with the new battries. If you store battries for a long time with out using them, they may result in battery drain. If this doesn't work. 3) Then it need a Physical check, where we can track if Power suply from battries are reaching till its destination or not. This is the way to narrow down the issue. Thanks you.
Taking the battries out then hold dowin the power bottom worked!!! THANKS
SOURCE: Konica Minolta DiMAGE 7i Digital Camera Problem
I just found a solution to my camera problem. It turned out to be the
batteries. We purchases some Rechargable Duracel with a 2650mAh rating.
After charging the batteries I put them in the camera and it started
right up and was taking photos like when we first bought it. I have not
been able to use the camera in almost 2 years and it turns out the
problem was weak batteries.
So anyone that has a Minolta Dimage
7i and cant get it to turn on make sure you have at least 2650mAh rated
rechargable batteries. The higher the mAh rating the better.
Hope this helps someone else. We are ecstatic that we can use our camera again. No more using my camera phone!!!
SOURCE: Konica Minolta DiMAGE Z6
I have used a 4GB card, but sometimes unable to read it direct from a card reader. This maybe my card reader limititions, but if i connected a USB cble to the camera, i could access pictures without a problem. Hope that helps.
SOURCE: Konica minolta Dimage x50 doesn't work
Buy the AC adapter plug the camera in without any battery, if it works then its the battery,if not its the camera.
Same problem different camera.I have a PowerShot A400 ( otherwise a excellent camera ).
How can I perform a " Physical check " ? ( 3 solution ).
I don't have experience .
Can be done ?
Thank you.
same problem...nikon d40x
My Camera has new batteries, Just bought not even 2 months ago, Will not come on it's like the batteries are dead.
it wont turn on
put in new batteries and camera will not turn on, sop put in more new batteries camera will still not turn on
will not turn on even with new batteries/charged batteries
Same camera - tried new batteries several times.
my camera wont turn on even when i put new batteries in..
i droped it before and it just turned off.
this time i droped it and it said the batteies are dead.
then never turned on since.
just makes this beebing noise when i try nad turn it on.. =[[.
CAMERA TURNS OFF AFTER OPERATING FEW MINUTES WITH BATTERY LOW WARNING?AND SWITCHED OFF AUTOMATICALLY?
I put in new batteries camera will not turn on.
Same thing, 6 mo old, started assin up 2 weeks ago, intermittent though, sent in for warranty work. Agree not the battery.
