1998 sl1 i r&i the motor and now i get spark and i have fuel but no start i nthink i miss conted the fuel injetors or firing order ??????????????????????
Firering order should be on in take manofold fuel injector are in harness should only fit on one way
If you need further help, I’m available over the phone at https://www.6ya.com/expert/mike_9693b5ad75773352
SOURCE: need a diagram of the firing order of spark plug wires from coil packs to spark plugs
FROM LEFT TO RIGHT, 5/2 3/6 4/1. ASSUMING YOU HAVE THE 3.1L ENGINE.
SOURCE: i need the firing order of the spark plug wiring
Here ya go:
Comments:
Jun 29, 2009 - Because I don't know your VIN number/letter:
Jun 29, 2009 - 2001 Ford Taurus
3.0 liter V-6 DOHC VIN "S"
This goes to the one above.
Jun 29, 2009 - This goes to the first photo:
2001 Ford Taurus
3.0 liter V-6 VIN "2"
Jun 29, 2009 - Sorry....this goes to the first photo:
2001 Ford Taurus
3.0 liter V-6 VIN "U"
Jun 29, 2009 - This is 2001 Ford Taurus
It is the same as VIN U:
SOURCE: firing diagram for a 87 olds delta 88 3.8
1987 Oldsmobile Delta 88
3.8 liter V-6 VIN "3"
Identifying Ignition Types I and II
On Type II coil packs, the coils can be replaced separately and the ignition wires are all on the same side of the coil pack.
With Type I Ignition
With Type II Ignition
SOURCE: need the firing order 7.3 power stroke
firing order is 1-5-4-2-6-3-7-8
here are the diagrams. I don't know how they will show up here. Post back if they are not large enough. include you email if so.
EVEN 2/ 4/ 6/ 8
ODD 1357
you may also need this one for the fuel line heater & glow plug relay
SOURCE: I need to know the firing order of my 1995 limited...
For the 1995 Jeep Grand Cherokee:
I do not know if you have the 4.0L In-Line (Straight) 6-Cylinder or the 5.2L V8; however I have included bothe below.
For the 4.0L In-Line 6-Cylinder:
Firing Order:
1-5-3-6-2-4
Cylinders:
(back)
|..6..|
|..5..|
|..4..|
|..3..|
|..2..|
|..1..|
(front)
Distributor:
...(back)
....5...3.(+)-screw
1...........6
(+)4...2
...(front)
For the 5.2L V8:
Firing Order:
1-8-4-3-6-5-7-2
Cylinders:
.......(back)......
|..8..|........|..7..|
|..6..|........|..5..|
|..4..|........|..3..|
|..2..|........|..1..|
.......(front)
Distributor:
.......(back)
.........3
...4.........6
8...............5
...1.........7
.........2
.......(front)
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
this is a 4 cly 1.9 L
