I have my PS3 connected to the TV. The audio cuts out every time and only when I'm using Netflix. It comes back only when I increase or decrease the volume on the remote. (thats the only way I've tried and it worked.) Help??
SOURCE: Audio cuts out
HDMI is not a universal standard. Some units will not talk back and forth correctly and can cause lock ups, loss of audio or loss of picture. Try switching to component inputs and see if it works better. Check your owners manual but I believe the component inputs will also accept 1080P as long as the Panasonic Blu Ray can output 1080P. Don't believe what the Salesman said if he told you that you have to use HDMI or you won't get HD.
SOURCE: i just bought a 52 inch samsung my volume does not
Did you try another time warner remote if yes then this is normal because if on/off works that means the volume function is not coded for the time warner remote because the set is to new.
SOURCE: I have a LG 47Inch
On the LG remote, push the "netcast" button, which is between Menu and Q.Menu.
You need to have a Netcast account set up at Netcast.com
