Toro 8 inch cut home duty trimmer
SOURCE: How do you remove the line spool cap on a toro
There are 2 tabs, 1 on each side of the cap. You need to press these in at the same time to pull the cap off.
SOURCE: I have a Toro 12 inch Toro Electric trimmer and I can't get the spool off to change. Any solution?
I am having the same problem - the spool should just come off by turning it counter-clockwise but is completely stuck. This model does not have any tabs that need to be pushed in to get the spool off. Very frustrating!
SOURCE: cordless trimmer 7inch cut model 51556 serial
Go here....you can download the manual....It's free!
https://homeownersolutions.toro.com/portal/server.pt/community/product_center/225#productDetailsPage
SOURCE: My Toro 12" Trimmer (Weed eater) needs a new screw
Your Toro electric trimmer parts are readily available through www.partstree.com . However, to avoid having to pay $10 in shipping for a $5 part, you should try to find your local Toro dealer. They probably have the part in stock. Go to www.toro.com and search on the dealer/distributor locator to find your closest dealer.
You will need to know the model number (5 digit) and serial number for your trimmer. These can be located on a small sticker on the trimmer.
1.Twist the cap off counterclockwise.
2. Remove the cap and spool.
Note: If the spring falls off, install it before installing the spool.
3. Thoroughly clean the cutting head and cap and inspect them for anydamaged or worn parts.
I put a flat head screwdriver into one of the two square openings (that snap it into place) and turn the screwdriver gently. The cap pops off easily.
