Gallery has code CL
SOURCE: Frigidaire Dishw. Error code CL
this just happened to ours and it turned out to be the gasket that seals the door.
when you see the CL error and the door is indeed shut, pull gently back on the door. if you hear a click and the unit starts running again, it may be the gasket.
ours lost it's ability to keep the seal, allowing enough 'play' in the locking mechanism for it to think the door was not closed.
Good Afternoon friend, I appreciate your post!
From what you have described your Frigidaire dishwasher is displaying an error code of "CL" and you have replaced the latch. Since the latch has been replaced it could be a problem with the wiring harness or main control. I would recommend having a professional out to perform a diagnosis and this will help you to avoid any unnecessary part purchases. Best of luck! -Matt
