SOURCE: Heater not gettin hot
Using a volt/ohm meter check the thermal fuse on the top left side of the heater canister for continuity. If no continuity replace the thermal fuse and the hi limit thermostat on the bottom of the heater canister.
These parts come as a set.
If I had a model number i could be more specific.
SOURCE: My machine shows error code F08 -Heater relay
This is not always the case.
Check all connections to and from the heater, the module , the thermistor, the pressure switch.
If you can, test the heater for continuity with a test meter.
Remove the connections to the heater to do this.
ENSURE THE POWER IS OFF BEFOR DOING ANY TESTING.
SOURCE: Hotpoint wt741 fault code f08
You need to check all the connections to the pressure switch the heater and the module as generally speaking it is due to a bad connection, you shoul not need to disconnect anything.
Hope this helps.
SOURCE: trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
SOURCE: Change thermostat, tested heater coil, dryer still
Hi, If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly. if
you dryer is gas check out this gas
no heat
tip.... If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip... heatman101
