My husband replaced the agitator dogs in our machine, but it seems to spin in one direction. Is this normal? Also the whole agitator piece spins including the center where you place softener it is all spinning in the same direction.
The purpose of the upper portion of the agitator is to push the clothes in a downward motion. As the agitator moves the dogs grab and on the backward srtroke the top portion rotates a quarter turn. In the spin mose the agitator only goes in one direction or your clothes would be torn to shreads.As the washer rotates back and forth, the dogs grab the inner walls of
the upper agitator and that forces the clothes into a downward movement
to the bottom of the tub. These dogs will wear out. To test whether or
not these are bad just grab the agitator while in wash mode. The dogs
should advance the top portion easily. If not then they are worn out.
To replace them you must remove the agitator and sit it on the floor.
Hold the base down with your feet and yank the top upwards. After
seperating the 2 pieces you simply install the new dogs and line up the
bottom with the top being careful not to break the little tabs on the
bottom agitator that hold the top in place.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
