Question about A H Fabrications Fish
How does the skimmer work? - A H Fabrications Fish
    New Friend:
  • 42 Answers
The skimmer process is pretty simple in spite the fact that aquarium product manufactures want to present it like rocket since. Protein skimming is simply using bubbles to collect protein in the water and bring to the water's surface.
Posted on Aug 30, 2012
SOURCE:
Can I use protein skimmer on fresh water aquariums?
Protein skimmers only work in fresh water under very high pressure and on salt water aquariums.
Aug 30, 2012 | A H Fabrications Fish
What is a Co-Current protein skimmer?
Co-current protein skimmer is one of the methods used in aquarium water skimmers. The air source is on the bottom of the reaction tube. Water is drawn up into the chamber with minimum dwell time. This skimmer is the least efficient of all skimmer designs.
What are the top skimmers picks?
The five most recommended aquarium skimmers are: Aqua Medic Turboflotor 1000 blue hang-on skimmer, Aqua C Remora protein skimmer, AquaticLife internal mini skimmer 115, Eshopps hang-on tank protein skimmer and the Lee's Counter Current protein skimmer. Each has its own benefit.
I can't get surface skimmer to work
im not sure what or even how you mean "swims away" as properly intalled it has a bracket that holds to pool wall , no the most problem ive seen with these is they sink !! pulling it and bracket right to bottom , this is just an adjustment of water flow thru float skimmer vs side skimmer (normal)
Jun 22, 2012 | Intex Swimming Pool Leaf Catcher Skimmer
How does a salt water sump work?
A sump skimmer is a very popular skimmer because it savesspace as opposed to some other types of skimmers on the market. Sumps are always outside of the tank. Here is a link to a great blog explaining howa salt water sump works with some helpful pictures:http://www.brettsreef.com/how-a-saltwater-aquarium-sump-works/
May 13, 2012 | Fish
How does a protein skimmer work?
Skimmers are very usefultools but are often forgone because of their bulk. Essentially, aquarium skimmers remove wastefrom your tank by producing bubbles that filter the undesirable material outand therefore lighten the load for the filter. They are generally used in saltwater tanks.
May 13, 2012 | Fish
Just had pool opened. They turned port dial to 2
Welcome to FixYa
Dear Sir/Madom,
If your skimmer is tied to your main drain, then both holes have to be uncovered for your skimmer to work.
If you have a separate line all the way back to your equipment from your main drain, then you may want to try to open both holes in the skimmers. Turn off your Unit to unscrew the retaining screw on the valve, and then slide the big end over.
If you've not had your pool run all winter, then you may have leaves/debris caught in the line.
If so-you can swing by a plumbing supply house and get a powerflush hose attachment.
  • Make sure that none of the holes in any of your skimmers are covered by the oval tab in the skimmer.
  • Then, if you have any valves on the inlet to pool pump, rotate them in such a manner to isolate the skimmer line that isn't working, making sure that it is open.
  • Place the hose and powerflush device in the upper inlet port of the pool pump, with the pump lid/cover and basket removed. Then, pressurize the line back to the pool with tap water.
  • If it doesn't release right away, then let it sit a little while, as you may have to "pulse" it as water pressure drops as water leaks around the clog.
  • Pulsing it means to turn the water on for a few minutes, then turn it off. Then, turn it back on, and then turn it off again.
Look down into the bottom of the skimmer. It will have either one or two holes, depending on your model. These holes are where the pool plumbing attaches to the skimmer. Most skimmers have threads inside the holes, and a copper or PVC threaded fitting screws into these ports. Squirt food coloring just above the holes and see if any of it is pulled down into them. This indicates a leak which may be caused by a poor seal between the skimmer threads and the fitting. If you put your finger into the holes, you should be able to feel where the top of the fitting meets the skimmer threads.Repair any cracks or breaks in the skimmer walls with epoxy putty.Use the silicone sealer to repair areas where the skimmer has pulled away from the pool wall, where the corners are cracked, and in tile cracks. These leaks are the result of a cracked bond beam or shifting soil from water getting into the ground around the skimmer.
Also Check this Link
I hope you got an idea...thank for Using FixYa...
Jul 03, 2010 | Hayward SAND FILTER, PRO SERIES
Cannot get pool pump to prime
turn the valve to main intake line (not the skimmer) and flood the pump with as much water as possible.
make sure there are no areas around the seals where air could get sucked in. when you get a full flow switch it to skimmer and main.
May 10, 2010 | Garden
Fish Logo
127 people viewed this question
Top A H Fabrications Fish Experts
Bill Boyd
Karen J Gray
Karen J Gray
Are you an A H Fabrications Fish Expert? Answer questions, earn points and help others
