Kenmore 54351 Dehumidifier Logo
Mark Schuessler Posted on Apr 23, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Runs for a couple of minutes and then stops
The dehumidifier seems to run fine for a few minutes and then it just stops. The bucket is not full and the auto shut off indicator light does not come on. If I remove the bucket and put it back in, the unit immediately starts to run again but will only run for a couple of minutes. Unplugging the unit and plugging it back in has no effect.
  • 3 more comments
  • Anonymous Feb 19, 2008
    got the same problem with mine.
  • leonsarah Feb 29, 2008
    My kenmore dehumidifier 50 pints (model # 58054501700) would runs for 10-20min. then stopped. What causes this?
  • Anonymous Apr 25, 2008
    yeah, the same problem has happened to mine. it worked perfectly fine all summer last year, plugged it in this year, now that it is extremely humid. i cleaned the filter every few weeks last year, and the filter was clean when i plugged it in for this year, so i know the filter is not the culprit of the problem.
  • Anonymous Apr 26, 2008
  • ctown955124 Sep 26, 2008
    Same problem. Does anyone else notice if the red button on the inside behind the bucket seems lose? We are thinking that may be the problem (with the lever not working with the button right).
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 19, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
13207
Points
8
Try cleaning out the air filter using cold water. I did not even know the unit had one until I had the same problem. Pull out the bucket. The filter is located where the front top edge of the bucket would be located if it were in the instrument. Remove it by pulling straight down. It may be taped to the instrument for shipping purposes. According to the manual, this should be done every month. I have had the machine since Katrina and this is the first time I have had a problem. Hope this helps.
Anonymous
Level 1:
New Friend:
  • Posted on Jun 22, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
13207
Points
I have two of these that are about a year old. They're both doing the same thing. They run for about 5 minutes then stop. They're driving me crazy! I'm going to throw them out and start again with a different brand.
Anonymous
Level 1:
  • Posted on Jul 31, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
13207
Points
After 6 months of use, I have the exact same problem with mine. The unit stops running after a few minutes. Sometimes the compressor doesn’t come on at all. I took it back to SEARS and they kept it for almost month. They replaced the capacitor and the main PCB. I brought it home and it worked, but then stopped working again. There is only 4 months left on the warranty. I want my money back.
Geterdun
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 184 Answers
  • Posted on Dec 18, 2007
Geterdun
Expert
Level 2:
Cheetah:
Answers
184
Questions
Helped
97224
Points
244
The time of year unit is used is an important part of how it works. in cold weather there is less humidity, so the unit cycles faster.there by collecting less water. the other reason could be the fan motor. it sometimes burns out due to dirt. if you don't clean the filter the dirt then travels to the coils which in turn send dirt to the motor. also the motor is working harder to pull air through the coils.
A
Anonymous
Thanks for the solution, but I already gave up on the problem. I tried changing the main computer box and the sensor assembly, neither of which worked. I scrapped the unit.
I have a FDL70S1 Dehumidifier. Unit runs for just a couple minutes and shuts off-blinking bucket full even though no water in bucket. Unit won't stay on
Dont spend to much time trying to repair dehumidifier they are very cheap to replace. Most dehumidifiers have lots of problems because they are made so cheap. Just replace the dehumidifier you will tank me in the end.
Unit stops running after a few moments and says bucket is full, when it is empty.
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
26helpful
2answers
Zenith ZD30 dehumidifier - 1 1/2 years old stopped working had a half bucket oc colledted water in bucket when it stopped. I checked the fuse on the circuit board and have continuity.
Unplug from wall. Take the front cover off and disconnect the 2 wires that attach to the humidity control dial. Plug back in. If it works, the problem is the humidty control dial (mine just went bad). With it unhooked, it will run constantly, but will still turn off when the bucket is full. To turn off, simply unplug.
2answers
Stopped running
water level sensor,problem by pass and test run unit if ok replace switch.
5helpful
Red light comes on for no reason. Danby DDR6588EE dehumidifier
I have a DDR4588EE (same model with 45 pint capacity) and had the exact same problem. It's caused by the float at the top of the bucket being in poor contact with the "full" detector button. When the bucket is not full, the float on the bucket is supposed to press against the button. When the bucket fills, the float is supposed to push up off the button which causes the unit to stop and the red light comes on. The problem is that for some reason, the float isn't pressing hard enough against the button to push it properly in when the bucket isn't full. I fixed it by sticking a few little squares of duct tape (3 or 4 layers) on the float to make it press the button more firmly. Seems to be working fine now. Careful not to put too much tape or it might press too firmly which would result in the float not releasing the button when the bucket is full, and water will spill over.
LG dehumidifier
I Have an LG Dehumidifier and water has leaked out to the basement floor, it has a hose that drains into the floor
Top Kenmore Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
