Question about Konica Minolta Bizhub C451 Copy-print-scan
What does Code C-1191 mean on my Konica Minolta C451?
The color in our documents is way off. Lots of red instead of normal coloring.
SOURCE:
  • 214 Answers
SOURCE: Scanning documents
You have to install driver with software, you can get it from www.konicaminolta.eu
Also you can scan with MS office or other Windows software, if you installed Twain scanner driver.
Find driver and software link below:
http://download2.konicaminoltaeurope.com/openmind/technic/kmbsdwl.nsf/psearch?openform&ch=MFP&dist=BEU&ui=en&dg=sw&prod=Di1610&dsg=&os=&lang=&ml=0&rid=&sub=&pcat=&pcc=
Posted on Dec 05, 2007
jqsababa967
  • 145 Answers
SOURCE: Konica Minolta c451: Tray 1 is not available
look behind the tray for paper....
if not do the folowning
power machine off from main switch sould be on the side or open the front door it;s on bottom left side.hold down the utility botton while powering on keep holdin untel prompted with message ...TROUBLE RESET press it should say ok than powr machine off wait 20sec power back on
hope that help
keep us posted
Posted on Mar 18, 2009
waqar697
  • 67 Answers
SOURCE: Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
Posted on Mar 30, 2009
  • 12 Answers
SOURCE: How do I get into service mode on a Konica Minolta
hi,
you can get in service mode by pressing: utility counter -> job details ( on lcd) -> stop -> 0 -> 0 -> stop -> 0 -> 1 .
Select "imaging process adjustment", then "graduation adjustment.
The copier prints a coloured sheet, you have to place it to the glass and the machine will read it.
Repeat sequenze 4/5 times. You have to make it in all three section " graduation mode" "resolution mode" and " i'm not remeber".
You can find clear information about graduation adjustment in a installation manual procedure.
Contact me, i can give you a pdf file.
Sorry for my bad english.
Bye.
Posted on May 15, 2009
firecontrol7
  • 6850 Answers
SOURCE: KONICA MINOLTA BIZHUB C350 WITH ERROR CODE C0960
Check your bypass tray, the tray is on the right side of the machine, the tray flips out for legal and 11x17 paper sizes. Check that there is nothing jamed inside, code says that the tray can't lift. so check for anything jamed inside down there. As to reset the code open then close the front door where you put the toner. Turning the machine on and off will not reset the code. but open and closing the front door will clear about 80% of the service codes.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jul 25, 2009
Blank copies on a Konica-Minolta c451 copier/printer.
Black or color or both? Check the transfer roller sponge looking roller on the right side cover that opens
Nov 09, 2016 | Konica Minolta Bizhub C451 Copy-print-scan
P7 error code in Konica Minolta c451 how to solve
replace the magenta (Red ) image unit.
Sep 14, 2016 | Konica Minolta C451
Konica Minolta c451 is showing white linen the printed work
for black and white??? or a color????? Means you might have something blocking the LASER for that color. print out a test chart for each color which one has the white line?
Jun 22, 2016 | Konica Minolta Office Equipment & Supplies
What's your question? my konica minolta c451e printing machine showed me an error code p21, what could that mean and it is not printing any image but black-green shade
P-21 - Color regist test pattern failure
• The number of points detected in the main scan direction is more or less than the specified value during main scan direction registration correction.
• The number of points detected in the sub scan direction is more or less than the specified value during sub scan direction registration correction.
P-21: Color regist test pattern failure
Relevant parts:
• Transfer belt unit
• PH unit
• Printer control board (PRCB)
Step/Action:
1/ Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2/ Change the image transfer belt unit if the transfer belt is damaged.
3/ Change the PH unit.
4/ Change PRCB.
(See Service Manual, pages 599, 603):
http://www.imcopexamerica.com/service-books/Bizhub/Color/bizhubC451_C550_C650FieldSvc.pdf
See also here:
Konica Minolta Bizhub c451 Reparacin de Fotocopiadoras YoReparo
Thread Problemas na C451 7 21
May 31, 2015 | Konica Minolta Office Equipment & Supplies
Konica Minolta C451 is ghosting only black color and ONLY when duplexing (first side is OK, just second side is ghosted). Black parts of print looks like smeared in direction how paper moves through p
what media are you using and what is the weight of the media you are using and does the copier know this and is correctly set
Mar 23, 2014 | Konica Minolta Bizhub C451 Copy-print-scan
Poor quality prints on fiery c451
well what do the colors look like print out the gradation pattern for each color in service mode see what they look like
May 27, 2017 | Konica Minolta bizhub Office Equipment &...
Konica Minolta bizhub C451
yes in your scan setting select scan type in there you will see compact pdf.That will make a 10 meg file be 900k even if it is color.
1twig
May 19, 2010 | Konica Minolta bizhub C450P Laser Printer
Mar 30, 2009 | Konica Minolta bizhub C450P Laser Printer
Konica Minolta Bizhub C451 Copy-print-scan Logo
215 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
