Hi guys.
i m using yahoo messenger 9.0.0.2034. i m facing a problem that my friends do not receive the messages i send them in timely manner but after some time and some times even they don't get my message and same is the problem on my side too.i cant get their message in proper time. And also get these message at once in a bulk. so than i re log in but after some message (sent and received properly) again the same problem occurs.Is it the problem of yahoo or my network . can any one help please.
Thanks in Advance
It is the problem with the network.Yahoo messenger operates on the internet speed provided.If you have 56kbps of speed allotted for yim, then the problem might with the other applications using the internet at the same time.So check for the internet usage through your firewall and cancel the unwanted applications.This should improve your internet speed and yahoo should be speeding up.
First try sign off and sign in for few times , if you still face the problem then uninstall the yahoo messenger and reinstall
Even i also faced the same problem , For few times sign off and sign in had worked or even restarting the PC also worked.
But after uninstalling and installing the yahoo messenger i got rid of the problem
If uninstalling and installing the yahoo messenger also not work then follow the below two steps
STEP -1
go to Start Button - Run - type regsvr32 jscript.dll - then press OK
STEP-2
go to Start Button - Run - type regsvr32 vbscript.dll - then press OK
now your yahoo messenger will work normally.
goodluck
I continue to get error messages not enough storage for this operation. I have plenty of memory. I dont have a lot of application running at the same time. I have uninstall the program twice and reinstall. Yet I continue to get this script error messages
