I can go to these pages when i press F8 and F6 and F12
Reinstall the operation system or check the hard disk to be in place ..cause it seam it opens up ok for the initial stage ..
try to see if your hard disk has a recovery partition ..and use it to go back to the factory settings ..To do that press f12 on start and on the boot screen choose the recovery partition if it has one ..If not..use a installation disk and make a clean install (format the C drive when you install .
SOURCE: dell inspiron 1525 laptop not detecting battery
Looks to me like the battery is bad, try another battery if you can and see if the laptop charges it. If it does then the battery is bad, if it doesn't then its something with the motherboard.
SOURCE: Dell D600 wont go into bios mode
Hi ,
if you wanted to get the bios setup you have to press Fn+F1 then you will go to the bios setup
SOURCE: My Dell Studio 1557 with Core I7, Window 7
Try pressing F12 as you power up, and enter the Dell Diagnostics. That can run tests on all your hardware to see what the problem is. If I had to guess from your description, I'd check the hard drive.
If your laptop is still under warranty, Dell will replace the hard drive for you.
Hope this helps! If so, please give a rating!
SOURCE: My Dell Inspiron Mini won't power up. When I
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
SOURCE: I have a Dell vostro 3700 purchased only a few
Hi.
Pop the install DVD into the drive and restart your laptop. When you see the Dell logo hit the F2 key to get you into the BIOS. Look for boot options in the list and set the DVD/CD drive as the first boot device. Save the changes and exit the BIOS.
The laptop should restart and boot form the DVD/CD drive so you can install the operating system.
Good luck and regards.
