This happens to me when we have a power outage.
I disconnect the router and put it in the freezer x 20 min. works every time and I'm back on the internet! I've tried reboot button (nope); power on/power off x 3 (nope). crazy I know.....
Make sure power is back up. Check both ISP modem and router indicator lights are normal. Test ISP connection with cable. If all is still OK then use the reset button in the back of the router.
FYI - ISP modem might also have a reset. I had to this for TV even though everything said OK.
SOURCE: I forgot my e1000's passward and lost wireless connection. How do I get passward for it?
you will need to access the setup page of the router and check the wireless settings manually. On the wireless tab you will find the WEP WPA network key
SOURCE: I lost y E1000'spassward and cannot access wireless connection
Have you installed Cisco connect software while setting up Your E1000 router?
If you have installed the Cisco connect then you will find all the settings there. If not then you can open the setup page of the router and check the wireless settings. Read Linksys E1000 Cisco connect
