Televison & Video Logo
ron b Posted on Aug 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a sony kdl 32-L5000. You can see the screen in the backround but their is a red, rolling (up) ghosting picture also. What could cause this.
Anonymous
Level 3:
Genius:
  • Master 1,182 Answers
  • Posted on Aug 30, 2012
Anonymous
Master
Level 3:
Genius:
Answers
1182
Questions
Helped
292563
Points
3377
If the problem is same with different input devices and you have ensured there are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
5 Related Answers
Anonymous
  • Posted on Nov 22, 2009
SOURCE: Sony Bravia 32'' picture problem - Sony KDL-32ML130
I am having same problem, started today, didnt find any solution to this question on forums :(
Anonymous
  • 148 Answers
  • Posted on Feb 03, 2010
SOURCE: 2 years old Sony Bravia KDL-52W3000 flat screen- I
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! ..Here is a picture of what you are looking for inside the tv...I hope this helped, if it did (or not)please rate, thank you!9441f5a.jpg
Anonymous
  • Posted on Apr 06, 2010
SOURCE: the picture has a shadow
you're LCD panel is gone. To replace it...$1500-$2K. But there is a silver lining to this dark cloud. No pun intended. Sony has posted on the US and Canadian site they will repair the XBR4 at no cost! i have the link right here. http://www.sony.ca/view/882.htm Canadian. http://esupport.sony.com/US/perl/news-item.pl?news_id=378&mdl=KDL46XBR4 USA.
It claims its the 46" but it appears to be a 40-52" problem. If you have an extended warranty it will pay for it.
Anonymous
  • 178 Answers
  • Posted on May 07, 2010
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
Anonymous
  • Posted on Aug 05, 2010
SOURCE: sony bravia kdl 46s4100 no picture
it sounds like your back light might be going out. You might be able to fix this by installing a new backlight inverter board.
I have a Sony TV model KDL-40BX412. There is a red ghost. Sometimes it is green. The longer the TV is on, the distance between the image and the ghost decreases, but never disappears.
Contact the authorized service centre for Sony. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
My Sony KDL-32M3000 has ghost (dark red) display with slow motion picture. What could be the cause and how can it be repaired. Thanks
Thats usually caused by bad flex tab bonds on the LCD panel itself. If you search for flex tab issues vidoes it will show how the pisture can get slow motion in areass as well as double images in that area.
Screen's picture has a ghost color. the picture looks faded or light.
somebody told me about this is because a wrong dc 20 volts line in the lcd panel and the solution could be a new wire between these two points with a 10 omhios half watt resistor. The principal recomendation is that we have very skill to make the solder in flex printed circuit bonded very close to lcd panel
4helpful
Sony KDL-40V2500 Screen is white
Remove the LVDS cable, the one going to the input of the tcon board and see if it goes dark, if it does the Tcon board has failed
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
