When I hit line 1, I get a dial tone, but pushing buttons to dial the number does nothing. The dial tone continues.
SOURCE: line buttons showing wrong phone lines
When a phone has only 2 lines, it's not programmed. By default, a Nortel system has 2 lines and that's all. Go into system programming and assign the number of lines and intercoms to a phone. After that, you can copy the buttons from a working phone to the new phone and you're done.
Carl
SOURCE: Nortel M7310 Phone moved to another jack, now no incoming calls
The reason your phones config is not the same as before is because configuration goes by what extension it is. So if you plug your phone in somewhere else, unless you have DN's configured, your extension changes, so say it was extension 21, but now that you moved it, its now 23, those settings remain on extention 21, so if you bought another phone and plugged it into were extention 21 is, it would have the settings that your old phone had before
To access the intercom by just picking up the handset, Press Feature **CONFIG (266344), Select <A. Configuration>, then go to <2. Line Access>, Select that and enter the extension of the phone you want to have access intercom by just picking up the handset. Scroll until you see <Intercom Keys: #,> make sure you have at least one intercom key. Then scroll until you see <Prime Line: #>, Press change until the display reads <Prime Line:I/C> And there you go. Hope i didn't confuse you
SOURCE: How can I get the dial tone turned back on without
To answer a ringing line by just lifting the handset that phone has to be programmed to ring on that line. This is done in the programming mode under 'terminals&sets/show set__/Line Access/Line assignment/Show line:__/...then your choices are: Appear and ring,Appear only, or Unassigned. Choose appear and ring on each line you want to answer from that telephone. Hope this helps.
Bill C. www.dyna-tech.com We also do remote programming and tech support on Norstar CICS and MICS.
SOURCE: How do I activate the
familirize with devices user manual whether has feature functions requested. Second, ascertain that device was least malfunctioning since acquired. normally, familirising with innovative devices makes expertise in functionality.
