Ok i came home and there was no hot water. I went to the water heater and there was about 2in of water in the water tray. The drain was dripping in the pan. I tighten up the valve and packing nut on the drain foist and stopped dripping. Will replace if i can get the water heater to work again. I vacuumed it out of the tray and took off the outer door to vac up the inside. Pilot would not stay lit so researched and replaced thermo coupler. Pilot stays lit now, but i turn on the gas and stays on for 2 sec and goes out.
What brand, model, and approximately how old is water heater?
This is important because water heater designs are changing quickly.
Did you remove door over combustion chamber to access thermocouple?
Newer Rheem water heaters have air intake under combustion chamber that has to be blown out using compressed air.
If this is different brand, then use mirror under water heater to see air intake.
Set water heater on bricks to avoid high water. Make sure drain line out of drip pan is 3/4" and terminates in good drainage location.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Put brass garden hose cap over drain valve.
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: Rheem 50 Gal Hot Water Heater will not stay lit
On the back of the gas valve (where you turn the temp up) there is a stem that actually goes into the tank that senses the temprature of the water it could be dirty or buried in sediment depending on how old the tank is, or just bad. if the tank is over 10 years old i wouldn't bother replacing the gas valve, the tank is probably not far behind. A new valve will run around $100.00 maybe a little less. You wont find it at menards or home depot in stock but they may be able to order it for you. Menards sells rheem products or try you local plumbing supply house. REMEMBER TO RELIEVE THE PRESSURE ON THE TANK BEFORE YOU WORK ON IT. IF YOU CHANGE THE VALVE DRAIN IT FIRST!
SOURCE: pilot light won't stay lit after release of gas valve.tried few t
Most likely it's time to replace the thermocouple, the safety device that makes sure the pilot is lit. New thermocouples are cheap and you can find them at most hardware stores and the big-box places (Home Depot, etc.)
Here is a site with basic information to get you going.
SOURCE: pilot light on water heater wont stay lit
The thermocouple has failed. It is the temp probe that goes from the pilot lite burner area to the control valve. Go to your local plumbng repair shop and buy one. Most appliance parts stores have them also. Take the old one with you and they will hook you up with an exact replacement. They are not that hard to change. Usually a nut or 2 screws in the temp bulb area at the burner end and a nut that threads into the control valve.
Make sure before you install the new one that the area where it mates to the gas valve is clean. Should be about a 20 min job including clean up with replacement parts in hand.
Testimonial: "exactly what I wanted yo know. thank you"
SOURCE: I have a Rheem PG50T9A
Hopefully just the thermocouple. The thermocouple is the small rod right next to the pilot light. The flame on the pilot heats up the thermocouple and keeps the gas valve on. You can replace it yourself. The thermocouple will be connect by a small nut on the underneath side of the valve, and you will have to pull the thermocouple out of the pilot assembly. Not an expensive part, you can get it at any hardware store. Hope this helps you .
