SOURCE: how to fix a stanley power-lock 25 ft measuring tape
Take the four corner screws out and the last center (short screw out). Split the shells in two pieces. Seperate the yellow or measureing tape from the black spindle tape. The spindle tape holds or attaches the measurement tap to the spindle. I have only seen a plastic spindle and this tutorial only applies to the plastic one. Take the spindle out and set the half casings on their backs, so you can see the cavity of the shells. The black spindle tape will be preformed to only wrap one way. Go ahead and attach the yello measuring tape to the black spindle tape. Pay close attention which side of the yellow tape is facing up or in our intended direction which is towards the center of the spindle. This way when you pull the tape out it is facing up for the person can see the measure marks. Wrap the tape tightly. If the tabs are broke and there's no way to secure the Yellow to the black, use two strips of Duct Tape and adhere the sections together. Do not use too much tape, since the clearance inside the spindle is tight. Once you wrap the tape inside, put a temporary piece of tape to secure the yellow and keep it from unraveling again. Next take a 1" wood screw and a battery powered drill and insert the screw into the center of the plastic spindle. Slowly tap the screw until it catches, do not drill the screw all the way in, only enough to catch in the plastic. Once the screw is partly into the plastic place the spindle into one of the half shells. The reason for the drill and screw is to return the tension back to the internal spring. Whichever side you placed the screw into you need to be sure to apply a clockwise turn. Keep the hex head of the drill so to not release the tension. At the same time place the spindle in the half shell and lock its square center piece into the shell. Now you can remove the screw from the center, then remove the tape holding the yellow meauring tape down, Still holding the measuring tape so it wont unravel, begin placing the last half shell on. Obviously you need to line everything up so the tape slides freely through its opening. Align the tape slide stop, which rests between the two shell halves. Replace the screws and remember the short one goes in the middle and holds down the belt clip.
Frank
SOURCE: how to replace the tape
Did it break and go flying up inside there? Take it back where you bought it, tell them you want a new one, they will replace it, all Stanley tools are warranted, the dealer may not want to do it, but he has to. You will never get it right by replacing the blade. I take that back, you might get it right.
SOURCE: I have a Stanley Power
you can try to pull the tape all the way out and then with a rag lightly oiled let the tape rewind back into the housing if that does not work then you probably need to purchase a new tape. for whatever reasona the spring inside has gotten weak. i use a tape daily and have had this same problem when a tape gets old or abused
