Camcorders Decks Projectors and Displays Service Six months warranty Free estimates Lens Repair Epson Repair Panasonic Camcorder Repair Sony Repair Sony Camcorder Repair Video...
Hi if you want to buy PCB board so you can buy from here http://www.dferrantielectronics.co.uk/ its provide the complete PCB manufacturing service and expertise in small to medium PCB assembly.
I had the same problem with mine. Turned out to be a bad solder connection on the Printed Circuit Board on top of the power transformer towards the rear of the reciever. If you flex the board by the connector going to the display you might see it come and go. I resoldered the connections and now all is good.
There is small switch located at front circuit board that is not working properly and causing "cover not open" message. Take off LCD cabinet section then remove front cabinet section, remove screws on circuit board and turn it to see that switch. There can be lose connection on switch terminals or switch is not being pressed properly with lens cover lever. Please check it carefully. Thanks.
My advice is as follows:
Ii the handycam was submerged without the battery on it the electronics may still be fine. you need to take it to the repairman who will open up all the circuit boards and dry them.
If there was a tape i the camera , the tape is damaged and cannot be used again.
The camera mechanism may also be damaged by the water through corrosion , so its absolutely important that you take it to the repairmen for drying as soon as possible.
However if the handycam was submerged with the battery on, then the electronic circuit boards are most likely damaged.
in this case you may weigh the costs of having the circuit boards replaced against buying a new camcorder altogether.
Hi, This problem is due to damaged of flexible board which connects LCD with the main board, The part number and description is given below: Part number 1-864-761-11 Description FP-185 FLEXIBLE BOARD figer is also for your convenience.
check outh the pins of the dv port ,is it fine ...four pins should be visible .... ok if nt then check the cable ....nd then in last if cable is fine too then u need to take it to service centre to get it repair .
