Speaker bluetooth paired fine first time with N82. I then needed to delete the pairing and when I tried pairing again the N82 could only find an 'audio-video device' and was not able to pair with it. I have deleted all BT devices in the phone and successfully re-paired with everything except the Veho speaker. Can you please help?
Hope it helps.
Power off your N8.
Remove battery from your N8 and reinsert again and then power it back on.
Activate Bluetooth settings and program it to become discoverable
Power off your bluetooth speaker
Remove battery from your Bluetooth speaker and reinsert.
Power it on again
Allow the pairing to proceed for both devices. Check and confirm/test whether operational
SOURCE: bluetooth to mobile pairing
Push and hold both vol(+) and vol (-) at the same time for approx 2 secs. The headset will falsh green and red lights. Get your phone to search for bluetooth devices. It should find the headset. Enter pairing code 1234 in phone. Done
SOURCE: plantronics 2XX pair code
The pairing pin should be 0000, most bluetooth device's use all 0's.
Hope this help's.
SOURCE: Need to re-pair bluetooth to phone
Go to ur phones bluetooth settings - activate pair new device - at the same time press and hold the on button on your blue tooth head set for about 10-15 seconds - this will enter the device into pair mode - on your phone - click on pair with new device etc etc, the default access code is either 0000 or 1234
SOURCE: i cannot delete paired device
i cannot delete paired device for my bluetooth. i cannot transfer data from any pc to my phone and from my phone to any other bluetooth device. my phone is samsung corby pro GT-B531
SOURCE: Just purchased Jabra Cruiser 2.
Try to reset and pair it.To reset follow below instruction
To remove the list, press and hold the Answer/End button, Volume up button and FM button at the same time. A beep indicates the list was removed from the speakerphone memory. The next time
you power on, the speakerphone will go into pairing mode as the first time you powered your new Jabra CRUISER on.
Thank You
