SOURCE: canon carepak extended service plan for pixma mp520
if you live in the uk i can offer you a few contacts who will give you
a price who will cover but it might be worth once it breaks just to buy
a new one because then you will have a years new warrenty on the
product. MP520 is not really worth extended service plan to be honest.
Hope this is ok
SOURCE: foutmelding 5100 bij een canon pixma mp520 all in
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: am imprimanta canon pixma MP520 Am
Try the Waste Ink Counter Reset Manual for "Service mode"
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (LED) should be green.
4. Press and release the RESUME button, the indicator (LED) should be orange.
5. Press and release the RESUME button again, the indicator (LED) should be green.
6. Release both buttons.
Then try another 4 steps to Reset Waste Ink Tank Counter
STEP 1:- Disconnect printer from AC power
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- Release the POWER button
STEP 4:- Press the POWER button again
