I removed the "protective plastic sheet" the camera store sold me (when it peeled up at one end after 4 years) and wouldn't stick in place. The screen appears coated with something, but all advice I read is NOT to use a long list of liquids. Absolutely no help from Canon problem solver line person, as they don't have a single suggestion for how to clean the display surface.
SOURCE: lens error message Canon Powershot A550
Canon A550 and A560 have the same body and most of the internal parts, including lens assembly are the same. Canon won't sell individual parts within the lens assembly. There could be two possiblities. One is (unlikely) that the lens assembly components have been knocked off from their position. The other is that because of a knock, or dropping the camera, the gears in the gearbox of the lens assembly are broken. These gears are the same as the ones in A530/A540, and are available from ebay for $12.50 including shipping. Checkout my site for how to open up the camera and the lens assembly to replace these:
http://pkrobot.freehostia.com/MiscElectronics2.htm
For A550 and A560, if you take it to the professional repair shop, it might not be cost effective, since it might cost around $90. Canon does not sell gears, so they might have to replace the entire lens assembly. The new camera is available these days for around $140.
SOURCE: Canon PowerShot A75 camera
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
SOURCE: horizontal lines showing in lcd monitor and pink cast to printed photos
Oh my goodness, don't disassemble and don't go banging your A95's up for this problem. Sorry I missed this post when you first submitted it.
This sounds like it might a defective CCD imager. If so, Canon should FIX THIS FOR YOU FOR FREE, including FREE SHIPPING both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
SOURCE: Canon Powershot SD1000: LCD screen display
Hopefully you resolved this already. If not, push the "DISP." button left of the MENU button. Pushing it gives you three options: black (for discreet shooting so your LCD doesn't give garner dirty looks from fellow concert goers), liveview, and liveview with info overlayed (shooting mode, ISO, etc.). Good luck!
SOURCE: my Canon S2 IS Powershot camera LCD screen turned black
A stuck shutter is another common failure mode for digital cameras, ESPECIALLY for the S2 IS (you should actually complain to Canon at 1-800-OK-CANON. If it is indeed a sticky shutter, they have been fixing this for free). The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Hope this saved you $99.
