I push power green stanby light blinks 17 times then red 5 times over and over again.
I push power green stanby light blinks 17 times then red 5 times over and over again?
This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:[email protected],we sincerely hope we can help you!
you can also check this boards whether suit you:
860 AB0 190DTLB PCH 200 000 170DTLBMH PI 190DTLB ETL XPC 204...
Thats caused by a shorted audio circuit. Replacing the K board will solve that issue. You can get the replacement K board from the following link scroll down to the bottom of the page and you will see the K board listed. They also have installation assistance if you need it.
http://www.tvrepairworld.com/sony_circuit_boards/sony_dlp_circuit_boards
SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
SOURCE: No picture or sound - Power Save light blinks red 5 times - nothing on the screen
Best first step = change lamp
SOURCE: Sony Wega stanby light blinks 5 or 6 times
When a Sony TV flashes five times, that means that there is an AKB circuit fault.
Six blinks is also a fault related to video problems, and regards a fault concerning the digital board and the Jungle IC (the main CPU).
This means that there is something wrong with the video.
Try first unplugging power for few hours, if that does not work, call a
technician, as several IC and components must be tested and eventually
replaced.
SOURCE: sony sxrd 60 in, won't power up--blinking red light 5 times
You need to replace your bulb. Order a replacement online---it's easy to swap and the instructions are in your manual. If you purchase one from a local dealer you will pay over $150 more!!!
SOURCE: 5 red flashs on power/standby light on kdsr60xbr1 screen blank,
Thats the error for lamp driver error. Which means the Ballast is most likely defective. You can get the replacement ballast for your model at the following link which comes with installation instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/kdfe42a10-ballast-assembly/cName/sony-parts
