Yes it is the transmission. A Mower shop will charge you about $225 to fix.. I order parts online and fixed mine for $90. Transmission consist of 3 gears which turns the rear wheels to self-propel.
im assuming you dont here any grinding, start by tightening the cable ( loosen the cable mounting bolt slide the cable towards the engine, make sure you leave some play in the cable so its doesnt engage constantly and re-tighten ) this is most likely your issue however if you re-test and get grinding you either need new drive gears and wheels, new transmission or possibly both, you said it does something just not powerfully this pretty much rules out your belt, highly doubtful its that worn out and if it came off of a pulley it would do literally nothing, however if you tighten it and the drive is almost normal but still weak you do have a worn drive belt
Check the drive belt and linkages/cables
Also the transmission area could have become plugged with grass/debris not allowing linkages to move properly.
It may just be a matter of adjusting the cable. Sometimes they dont get them adjusted just right from the factory,heres what you do. Locate the plastic shroud in front of the push mower that covers the drive unit.Determine which screwdriver or torx bit is needed to remove shroud and remove it. After removal you will see a pulley with belt around it, as you pull the handle back to engage self propel you should see the pulley move into the belt to put tension on the belt. You can do this with it running to see if enough tension is being put on the belt,if not, locate the cable end where the small bracket holds the cable in place. Loosen the cable bracket and move cable until you have correct tension again,hope this helps.
Your self-propel is probably belt driven. Belts can make an awfully lot of noise when unhappy. Possible it has rolled over and is running on the wrong side of the belt or is worn and just needs replaced. Hope this helps.,
