Question about Janome MC 4400 Computerized Sewing Machine
Can't change needle position (left, center, or right)
My mom just bought the MC 4400 machine and we cannot get the needle position to Center... it is in the far left position, even though the computer display changes from 0-5 when we press the appropriate button. The needle does not move at all. I have tried changing to different stitches, from 01-04, etc., as the manual says you can change the needle position in any of these stitches. I have taken the foot off to be sure it was installed correctly, and it appears to be.
  • augiec7 Jul 06, 2008
    Needle will not move left or right and bobbin is not stiching properly
6ya staff
SOURCE:
jessee007
JP Services
  • 310 Answers
SOURCE: loose stitches every 1
test it out on 2 pieces of material by rotating the wheele by hand. pay close attention to the 1" area. when you turn it by hand you can feel the area of question. is your bobbin spooled correctly. if all fails read the directions.
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Jan 16, 2008
bargainbox
Hassy
  • 1388 Answers
SOURCE: Janome MC 9000 Embroidery/Sewing Machine
This is the diagnistics routine for Janome 9000.
Run each test in sequence from 1 - 13, or until you find error
The results of this may not be what you want to hear, and may be why no-one has yet replied....I hope for an easy resolution for you
If you are having trouble reading this here, simply send a request via the "contact us" page on:
www.bargainbox.com.au
Martyn
Posted on Feb 16, 2008
Anonymous
  • 3 Answers
SOURCE: Changing stitches
You probably have not adjusted you stitch width and length.
Also a manual for this machine is currently being sold on Ebay for $4+. Probably would be a good investment for you.
Posted on Mar 29, 2008
bargainbox
Hassy
  • 1388 Answers
SOURCE: Sewing machine not stitching at all
SIX Layers !!!!
You really need a size 16 needle that won't bend and miss the hook by the sound of it....can you sew on less challenging thicknesses OK ??
If not, the timing may need adjusting...here is a link to assist:
HERE
Posted on Aug 02, 2009
Anonymous
SOURCE: I just bought a janome mini sewing machine. I
First, in order to get the bobbin thread up, you have to turn the wheel backward, not forward. If you try this, and it is not the problem, keep going.
Next you need to check the needle. There is a screw on the right side of the needle carriage right underneath the underside of the top...unscrew this and the needle should come right out. The flat side of the needle shank should go towards the back of the machine. If it isn't, switch it so that it is and try again.
If this doesn't solve your problem, what has happened is that the gears in the machine have gotten out of alignment. There is an easy fix:
Take off the plate that covers the bobbin chase...there are two screws one on each side. Remove these...you need a stub screwdriver, because regular ones will not fit under there.
Remove the bobbin carriage and the bobbin, making careful note of how they fit back in. Take a picture before disassembling it so you have a reference.
The part that carries the thread around the bobbin is still in the machine. Turn the wheel and you will see it rotate. What has happened is that the needle is not going down in the machine at the right point because someone kept sewing after it jammed and one gear kept going while the other one didn't and now it is out of alignment. These machines have plastic gears and the can slip past each other if you aren't careful not to stop immediately when they jam.
To fix it, you are going to have to do some trial and error. Grab the rotating part of the bobbin chase and hold it firmly. Rotate the wheel forward until you hear it click once. Then rotate the wheel backward again and see if it grabs the top thread. If it doesn't, repeat holding the bobbin chase and turning the wheel forward until it does.
Once you have the gears basically aligned, you will need to reassemble everything. Put the face plate back on and put at least one of the screws in all the way. The face plate holds the bobbin chase in correctly and if you don't fasten it it will not work correctly.
Now try sewing. If it starts to jam, stop immediately, cut the threads and look at the back. If it's a loopy mess, you are going to have to dissamble as before and again grasp the bobbin chase and turn the wheel forward one more click, then reassemble and try again. Eventually, you will find exactly the right alignment and the machine will sew perfectly.
I just had to make this fix on my own machine...I didn't want to take it in for repair because the bench fee alone would cost as much as the machine did!
There are some great video's on YouTube for help with threading the machine...look for StampTV and you should find them. Good luck!
Posted on Apr 21, 2010
When trying to use the zipper foot the needle will not stay positioned to the side and keeps returning to center hitting the center of the zipper foot and machine stops
set the machine to straight stitching which should keep the needle in the center position
a zipper foot is a normal foot with 1/2 missing
It it still wanders , take it in for a service
Dec 31, 2015 | Sewing Machines
Bernina 930 change needle position
Look at the knob which creates the zig-zag stitch (1-4) at the top right of your 930. In the center of that is a silver knob that rotates right and left. That silver switch moves the needle position right and left.
Mar 22, 2015 | Bernina Sewing Machines
The needle always moves to the left. How do I keep it centered?
On some machines, there is a needle position setting, or a stitch selection for left, right and center of the needle position.
Happy New Year,
Kelly
Embroidery Services
San Diego, CA
Dec 30, 2014 | Sewing Machines
Sewing machine sews good in center needle position, why does it not stitch,when moving needle position to right f left?
Hopefully it is a bent needle. Replace the needle first. If that doesn't work you will need an adjustment made on the hook. That is when you will need to take your machine to the repairman.
Oct 29, 2014 | Sewing Machines
Singer 6416 sewing machine
Not familiar with this particular machine but make sure you have the needle all the way up. They won't change the position otherwise.
May 11, 2014 | Sewing Machines
Needle position won't hange
When you turn the machine on does the needle bar initialize? I.e. Move to the left, then to center.
Nov 03, 2013 | Brother SE400 Computerized Sewing Machine
I cannot ser a straight stitch with the needle in center position. The manual does not state how to adjust needle position (left, center, or right). Because the needle is in the left position and the...
Some machines are not designed to sew the straight stitch with the needle in the center position. Some are left or right position to do that and it is simply the way they were designed. Linda at Relics
Jul 04, 2011 | Husqvarna Huskystar 215 Sewing Machine
When I turn on my pfaff the needle is not positioned in the center.
Try locating the needle position knob that shows a single dot in each of the 3 positions (left, center and right).
It might look like this
Right (___*_), Ctr (__*__), Left (_*___)
Jan 02, 2010 | PfaFF Sewing Machines
Bernina 1630
I have a Bernina Virtuosa so not the same machine - but this may help. There is an icon on the front of the machine - it is a needlepoint pointing at a dot in an oval - there are arrow buttons on either side. These move the needle left or right of center and it shows on LED screen. I checked mine just now and if you turn machine off and on it resets to center automatically. Hope this helps - Happy Sewing!!
Dec 15, 2008 | Bernina Virtuosa 160
Sewing Machines Logo
73 people viewed this question
Top Janome Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Thomas F. Schneider
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
