SOURCE: I NEED THE NORDICTRACK 9600 INCLINE TRAINER TREADMILL SCHEMATIC
contact me @ [email protected] I will send this to you.
SOURCE: Does anyone know how to remove the plastic foot
you must remove the screws allens including those found beneath the label. be careful when lifting
SOURCE: walking belt on NordicTrack C1900 is to loose, how
Tighten the rear roller bolts evenly with the unit off. The correct tension is when you firmly lift up on the right and left edges in the middle of the walking belt and get 2-3 inches gap above the walking board. If one side is looser than the other, the walking belt may wander sideways. Turn the rear roller screw on the side that it shifted to in a clockwise manner(1/2 turn at a time). Test on a low speed and adjust as needed. (you may manually recenter the walking belt with your foot if it shifted too far to one side and is rubbing on the plastic edges.) You likely have a worn motor belt that needs changing or even a pulley on the front roller that is slipping and needs replacing. They all cause slippage.
