Kitchen Ranges Logo
Posted on Dec 22, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Convection fan not coming on
The fan for the convection oven is not coming on, the display is showing the fan rotating but it is not, it sounds like the panel is trying to turn it on with an intermittent click noise.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 324 Answers
  • Posted on Dec 22, 2008
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
324
Questions
Helped
120856
Points
632
There is a thermal fuse that may be open you can check your wiring diagram.
How do I fix the Convection Fan not running/working
Make sure that the fan motor is being energized. If so, and it does not run then the fan needs to be replaced.
2answers
Convection fan runs from start up , but when temp ia achieved , fan stops working and shows con on the display
Search Results
    Frustrated with new Samsung stove! - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETWe purchased a smooth top, convection Samsung range , with delivery on ... I seem to have the same problem with my new samsung range FER700WX. ... That ovenwould not reach temperature and if it did, it would not keep the temperature. ..... 3) as the oven restart the convection fan or fans blow such hot air the food in ...
    Convection 101: A Guide to Cooking With Fans - Oven ...
    ovens.reviewed.com/.../convection-cooking-101-a-guide-to-cooking-ba...
    Apr 4, 2015 - Problem is, it uses a ton of water. 6.2 ..... Convection ovens use a fanand an extra heating element to correct ... it's best to reduce oven temperature first, before adjusting cook time. ... range or wall oven, there's simply no reason not to ponyup. ... From futuristic to freaky, these fixtures run the entire spectrum.
    New Bosch range convection fan not moving? - Home Forums
    ths.gardenweb.com > Home Forums > Appliances
    Oct 8, 2007 - On my range (the slide-in version) the cooling fan runs even when in ... I was the one with the Bosch fan problem and if there is a problem with ... Mine does stop turning when I open the door and starts again when I ... convection roast feature, and once the oven reached temperature, ... Sign Up to Comment.
    Troubleshooting Gas Range and Oven Problems ' Back ...
    blog.etundra.com > Tundra's Tech Talk
The fan doesn't work on the dual fuel convection oven. what should I do?
check power on fan motor 120 volt or not. if power 120 volt change fan motor
Convection oven making rattling sound.
It is most likeky that the fan bearing is worn and thus causing the rattling sound. You will probably need to replace the fan. Check first that there is no obstacle in the way of the fan rotating.
Replacement of the fan will require the back of the oven to be removed giving access to the fan unit, which will need to have the wires disconnected and the fan assembly unbolted. Fitting is the reverse.
Always remember to switch off the power before working on electrical equipment.
Jan 07, 2010 • GE Ovens
Convection setting loud noise
try going to the place u bought it and see if they can tell u what to do with it. better safe then sorry
2answers
Broiler
can you hear the convection fan motor turn on? if not that would be your problem.
Fan for convection oven not working
Maybe you could throw out the oven and buy a new fridge
Convection fan not working
Check for a bad fan motor or a jammed blade.
Top Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
