When ever I try to call somebody it just says call ended then I tried to call the phone then it said phone busy. If I try to connect to a network it says failed to connect and I cannot even receive text or send them!
SOURCE: I have SGH J600. Can only receive and send texts,
did you check on your volume is up to check if you can hear the other party. normally your problem happens when the volume i down. So try making a call then turn the volume up to double check
SOURCE: Phone: Samsung Propel Problem: I
Mine also did this. It only does this when you do not have signal. If you do have signal and it still does this you just need to call ATT and confirm it with them. They ended up sending me a new one that has better software on it for free.
SOURCE: Samsung Star Multimedia Messages Won't Send
hi dear friend YOU ONLY SEND AND RECEIVE TEXT MESSAGES OK. contact your vendar for mms messages.
SOURCE: cannt send text messages through samsung set i8510
try this... 1st Make Full Eprom Reset *2767*3855#
After Rebooting Mobile.
3. Type *7465625*638*00000000*00000000# then power OFF phone &
Restart again
4. Type #7465625*638*00000000# (to permanently unlock the phone) then
power OFF phone & restart again
Send complaint to your state's consumer affairs. The first time I had this problem, I brought it to Verizon to get it repaired. I was told that it was a common problem, but that they could not fix it. I fought with Verizon and finally received a replacement. This time, I do not have the energy to fight again. I am going to complain to either my state's consumer affairs or attorney general.
