If you're using a conbverter box with this AKAI TV then you don't need it, it already includes an ATSC digital tuner inside it.
If the channel you're referring to is actually KMBC in KC, MO, you may be too far away from their broadcast towers to receive a digital signal, they broadcast on UHF channel 31 which is actually digital channel 29.1, if you go to
http://www.antennaweb.org and type-in your address and then click continue on the next page it will show a list of all the broadcast antenna's for your area and how far your house is located from them.
But first, if you have this AKAI TV where you posted your question, then remove the converter box and attach the antenna coax cable to the digital input on the TV and then scan for channels from the TV itself and you should get better results.
Good Luck!
Ren
