You have to enter its service mode to get it out from hotel mode. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the left top left corner of the display window. It will make search easy. Some times, the ads attached with each posts both at the right and bottom, might help you to find the availability of spare parts. There are more than 670 posts to different brand TVs now.
SOURCE: NEED A CODE FOR SANSUI 19" HDLCD1908 TV
Sansui Television 1023, 1107, 1122, 1273, 1382, 1383, 1384
Try one of these yet?
SOURCE: my sansui 19 in hd
Set the refresh rate to 60hz and shut down your computer. Connect it to the tv as per the tv manual. Power up the computer.
SOURCE: my sansui 19 in lcd tv is not receiving signal from my dell compu
check the cable,check the graphics adapter is seated in ur system perfectly,check if any boot sirens came from ur cpu when starting the system.
SOURCE: driver for monitor
if u r using xp sp2 ,sp3 or vista no drivers r required for any monitors as such drivers r installed by windows automatically.ok next is go to divice manager and search for monitors if ur monitor has any issues it is displayed yellow.ok even if the device manager doesnt show up any issues with monitor,u can always upgrade the drivers to the drivers that came with the monitors installaion disk that may be supplied with ur system.
SOURCE: PIP ON SANSUI LCD TV
Lets start at connections. What is your cable source? Do you have a converter or cable box connected to your TV?
YES : You must have two connections, so you will need to run a second coax cable from the wall. This can be a $10 fix and a 15 min hook up. (Ask if needed). You will also have to be using your TV through caox inputs (TV Source on TV)
NO: You will need a second line ran and hooked up to your TV input. (Ask If need specific hookup on model)
