Master
- Posted on Aug 28, 2012
Re: t652n 202.03 paperjam
1Open the upper-front cover and remove the toner cartridge.2
Look into the printer. Remove any jammed sheets of paper that you find there.
- If the print job only consisted of this one page, reinstall the toner cartridge and close the front cover. Press the button to clear the error, and then try printing again.
- If the print job consisted of more than one page, confirm the entire paper path is clear before printing again. Do the following:
- Remove the top paper tray ('Tray 1').
- Remove any jammed or partially-fed sheets of paper you find here, then reinstall the tray.
- Go around to the back of the machine and open the upper-rear cover. Remove any jammed sheets of paper you find, then close the cover.
- Once you have confirmed that the entire paper path is clear, reinstall the toner cartridge and close the front cover.
- Press the button to clear the error, and then try printing again.
- If you cannot locate any jammed paper under the toner cartridge, then check the rest of the printer for any jammed paper. Do the following:
- Remove the top paper tray ('Tray 1') and look for any jammed or partially-fed sheets of paper.
- If you do not find any jammed pages there, reinstall the tray and go around to the back of the machine. Open the upper-rear cover and look there.
- If the entire paper path appears to be clear, close the rear cover and power off the printer. Reinstall the toner cartridge and close the front cover. Power the printer back on. If a 200 error continues on power up, a sensor in the printer may be malfunctioning. This will require a service call to correct the issue. Please contact Lexmark Technical Support for additional information (see Contacting Lexmark Technical Supportbelow for details).
