Help
.Disconnect the negative (black) cable from the battery, then remove the positive (red). Unbolt and remove the upper support rail for the radiator.
SOURCE: 2000 dodge intrepid 2.7 sputtering, revs up
you need to ck some basics you could have a vacuum leak which would hide during warm up but cause havoc when hot,the leak would cause high idle then your pcm would try to lower idle to spec thru use of idle control motor causing surging idle ,also fuel pressure needs to be checked while acting up,may be more cost effective to pay for an hour of diagnostic.
SOURCE: To remove an alternator on a 1998-99 Intrepid, on drivers side
FIRST OF ALL.TURN OFF RADIO SO YOU WONT LOSE RADIO CODE.FOR THE 2.7L ENGINE.DISCONNECT NEGATIVE BATTERY CABLE.REMOVE THE LOWER PLASTIC SPLASH SHIELD.REMOVE TRANSMISSION COOLER AND POSITION IT ASIDE.REMOVE THE LOWER RADIATOR CROSSMEMBER SUPPORT.LOOSEN BUT DO NOT REMOVE.ADJUSTING T BOLT AND THE PIVOT BOLT.LOOSEN DRIVE BELT ADJUSTING BOLT.REMOVE OR DISCONNECT THE FOLLOWING.DRIVE BELT.REMOVE ALTERNATOR ELECTRICAL WIRES.REMOVE PIVOT BOLT CAREFUL NOT TO LOSE THE SPACER.REMOVE THE ALTERNATOR. NOW THE 3.2L AND 3.5L ENGINES REMOVE THE NEGATIVE BATTERY CABLE.THEN REMOVE THE LOWER MOUNTING BOLT AND PIVIT BOLT.REMOVE DRIVE BELTTENSION BOLT THEN DRIVE BELT.REMOVE BRACKET LOWER MOUNTING BOLT AND PIVOT BOLT.THEN REMOVE THE ALTERNATOR + ALTERNATOR FIELD CIRCUIT PLUG + ALTERNATOR B+ TERMINAL NUT AND WIRE.THEN PUT EVERYTHING BACK VISA VERSA.
Testimonial: "Thank you , as i am a senior i will try the recommendation, and let you know , but it appears very excellent help and i thank you for this Cheers Ste"
SOURCE: how do you replace a coolant air bleeder on 2000 dodge intrepid
unscrew it out of the thermostat housing and screw a new one in. make sure cars not hot when you do this.
SOURCE: where is cabin air filter 2000 dodge intrepid
The 2000 Dodge Intrepid is not equipped with a cabin air filter.
SOURCE: 2000 Dodge Intrepid / need help to replace front map dome light.
how do u turn interior light of with door open?
Unhook the battery. Remove the negative cable first, then the positive one.
Lift the front end of the car, using the jack, and place it on jack stands. Refer to your owner's manual for a placement diagram--they are in an unusual location for the 2001 Dodge Intrepid.
Remove the plastic splash guard from the underside of the engine. It is held in place by several bolts.
Unbolt the transmission cooler, then move it out of the way. Don't remove the hoses--just the bolts.
Remove the brace that holds up the radiator. Use a jack stand to hold up the radiator.
Loosen the adjustment T-bolt and pivot bolt on the alternator, but don't remove them. Remove the belt.
Unscrew the nut that holds the battery cable to the alternator, then remove the cable. Unplug the other electrical connector, as well.
Unbolt and remove the alternator.
Replace the alternator. The steps are the reverse of the removal procedure. Torque the nut on the battery cable to 90 in-lb. Torque the mounting and pivot bolts to 40 ft. lb.
2000 intrepid and battery keeps dieing . Battery brand new and alternator tested and good. Checked battery cables and clean and tight. Any ideas what to look at next or what the problem may be ?
